Hi Mike,
I'm very new to detailing and tried my first shot at detailing my 2011 VW Gti. I washed, clayed and polished the car. For polishing I used a porter cable 7424 XP with orange pads in Optimum hyper compound and white pad on optimum hyper polish. Detailing alone took me 2 days in the garage, and while I watched some videos and read guides, Im sure I was ineffective in my process. After the two polishing steps mentioned above, I couldn't leave my Car in the garage anymore and had to drive it. My plan was to do a sealant and eax afterwards, but I ran out of time. I'm not too pleased with the results, and although it seems I removed every swirl mark on the Car, I ended up seeing straight line scratches after polishing. Foolishly, I didn't use the test spot method and just continued to do the entire car. My question is, how do I proceed mike? I don't mind the scratches so much , it doesnt bother Me all that much as my main goal was to protect the paint from the upcoming harsh Canadian winter.
1. If the paint surface is smooth to the touch, can I follow up with a sealant and wax 2 weeks after the original polish work? Or do I have to redo the work to remove the scratches before I apply a sealant and wax? If not, is it enough to just wash the car again, then simply proceed with a sealant and wax without claying and repolishing?
2. If an orange pad wasn't sufficient to remove the scratches I discovered afterward, would you recommend going to a more aggressive pad, or retry with an orange pad and same optimum compound I used the first time around to see if I can make it better? Do I try new compound maybe?
3. I did a test in mid air to spin a used up ( but clean and try) white pad 5.5 "LC CCS and it seems the buffer is much more hesitant to spin smoothly than an orange clean pad. I put the two pads on my hand and the white one feels heavier. Is it possible that the material has baked in so much into the pad that it is affecting the rotation? I tried another brand new red pad , same size and it also spins freely. I noticed as a result, as I was polishing with the white pad after while, the buffer was wobbling on the surface and wasn't polishing very flat, and the motor felt bogged down. Does the weight of the pad have any impact on rotation?
Thank you very much Mike
