Question on McKee's 37 Coating Prep Polish
ivygreen
Will McKee's 37 Coating Prep Polish do anything to correct paint, or do I need to decon, clay, correct the paint, and then polish with McKee's Prep Polish before coating?
Oh, and while I have your attention, is there any advantage to layering McKee's coating?
Thanks in advance for your help.
Straight from the product description. In short the pad will be doing the work as it is a non-abrasive polish. As far as the coating one coat is all that is needed per Nick's direction.
McKee's 37 Coating Prep Polish is a non-abrasive chemical polish that deep cleans automotive paint, ridding it of below-surface contaminants that will prevent a coating, paint sealant or wax from properly bonding. Formulated without any silicones, waxes, sealants, polymers or fillers, McKee's 37 Coating Prep Polish leaves nothing on the surface, making it the ideal polish to use before applying any product that requires a 100% oil and wax free surface.
McKee's 37 Coating Prep Polish is the only polish specially formulated for application of permanent and semi-permanent paint coatings. By creating a polish that doesn’t have any oils, waxes, silicones, polymers or fillers, you can apply a paint coating immediately after polishing your paint with McKee's 37 Coating Prep Polish. There is no need to chemically strip the paint using isopropyl alcohol or volatile wax and oil removers.
Paint coatings have quickly become one of the most popular forms of paint protection thanks to their ability to provide years of paint protection. For a paint coating to properly bond to the surface, the paint must be rid of gloss-hindering below-surface contaminants and imbedded dirt. While most polishes will successfully do this, they typically leave a wax, polymer, oil or some type of filler behind, all of which will prevent a coating from properly adhering to the surface. McKee's 37 Coating Prep Polish removes unwanted contaminants without leaving anything on the surface that will prevent a paint coating from properly bonding.
McKee's 37 Coating Prep Polish is non-abrasive and safe for all paint systems. Formulated with an advanced blend of chemical cleaners, McKee's 37 Coating Prep Polish will make light colors appear brighter and dark colors appear wetter. McKee's 37 Coating Prep Polish will intensify the gloss of your paint by removing below-surface contaminants that hinder the shine. What’s more, McKee's 37 Coating Prep Polish will remove other topical contaminants including water spots, road film and light surface staining.
McKee's 37 Coating Prep Polish can be applied by hand or machine. This versatile polish has been tested and proven to be compatible with all paint coatings. Like other products that bear the McKee's 37 name, Coating Prep Polish is exceptionally easy to apply and remove.
Put an end to mixing up alcohol and spraying volatile cleaners on your paint and prepare it for a coating using McKee's 37 Coating Prep Polish.
