question on removing LSP
joeyp3021
will DP Prep Polish or WG Paint Enhancer remove my layer of sealant?
-What sealant is on the vehicle?
-Are you wanting to actually remove the sealant; or do you want it to remain
on the vehicle after the use of one (or both) of the products you have listed?
the sealant if Wolfgang 3.0...I want to remove the sealant...I did a paint correction end of may and got the car about 95% corrected, its a garaged kept and only driven on weekends but has very soft paint so I was trying to avoid claying this time.
It may take a more abrasive product to remove the WGDGPS 3.0,
than the two products you listed.
What are you planning to replace the WGDGPS 3.0 with?
I was planning on collinite 845 then top with chemical guys petes 50/50
