questions about detail order
redline
this is the car i am gonna detail. the question i have is after i wash and clay.
do i
1. use red moose glaze then use upp sealer and then use souveran.?
2.use upp sealer then souveran?
It all depends on what you are after, durability or looks.
Number 1 will give you dripping wet looks but leave the 4* UPP out. RMG is extremely oily and does not sit well with a sealant topper instead use only souveran.
Number 2 will give you more durability.
Just finished a car with RED MOOSE Lasthope05 is right - You will notice the "WET LOOK" ! I would let it sit a while before you put anything over it for Durability, this will avoid clouding that might be very noticeable on Dark Colors !
