trlblazer3 said:Yea like I said I'm not too sure, I thought I read that somewehere but I'm probably mistaken. I have no clue since I've never used car wash as a lube.
D&D Auto Detailing said:I wash, clay, wash, dry. The second wash is just a soak down with the pressure washer foam gun.
Finish Kare 425.Its a quick detailing spray.Its also great as a clay lube.Hope that helps,check out their website.devst8 said:what's FK 425?
carguy said:THanks all of you for your replys on this issure,thats what ive been doing, claying while washing seems to work for me, i will try washing, rinse then clay to see if there is a difference, also i use a 50/50 water and alcohol wipe down after i dry, seems to make the surface squeeky clean. Have any of you done this?
