Questions on the Foam master
Largebore
I just received my foam master sprayer today.
I have a few questions that the instructions do not seem to address.
[1] I understand how to set the dilution on the sprayer. But it only goes down to one ounce per gallon. What if you have a soap that supposed to be diluted at a lower ratio?
[2] The instructions for the DP Extreme soap says to put in two ounce of soap into the container and then add 6 ounces of water. NO problem, But it does not say what dilution ratio to set on the sprayer ?
[3] Do all soaps supposed to be diluted within the sprayer bottle 2 oz to 6 oz ?
Feed back please
I use 3 oz of DP soap and fill till almost the top and the dilution depends on how much foam you want if you you look at the holes you can tell that there are smaller holes and bigger holes the one with the bigger opening will let more foam out and drain the can faster most guy and girls here put it in the middle setting
