Nick@Autogeek said:Knowledge is infinite, and everyone loves a shiny car, so act like a sponge and start absorbing because I'm going to create the definitive explanation on one of the most popular topics on car care and detailing forums across the globe - spray waxes, quick detail sprays, and waterless washes.
Here is my definition of a spray wax, quick detail spray and a waterless wash.
Spray Wax: A product containing protective properties to protect and beautify the surface that it's designed to be applied to (ie: paint). A spray wax (sometimes referred to as a "spray sealant") is designed to be applied to paint that's squeaky clean and free of any dust, dirt, or contaminants. A quality spray wax will easily yield 3-4 months of stand-alone protection. A spray wax (spray sealant) is often used as a "booster" over an existing wax, sealant or coating.
Nick's Favorites:
Quick Detail Spray: Just as the name implies, a quick way to touch up your vehicle's finish. A quick detail spray often contains carnauba or polymers (some contain both!) to spruce up your vehicle's appearance. A quick detail spray is often used after a wash to boost the shine. Most quick detail sprays can also be used to remove light dust (don't worry, we'll get more into that later). While a quick detail spray can contain carnauba or polymers, they don't provide too much paint protection, like a spray wax does. Lubricants ensure you don't scratch the finish as you wipe away dust.
Nick's Favorites:
- Pinnacle Crystal Mist
- Optimum Instant Detailer & Gloss Enhancer
- Blackfire Midnight Sun Instant Detailer
Waterless Wash: A waterless wash (often referred to as a "spray on car wash") contains an advanced blend of lubricants and cleaners designed to safely lift dirt and soil from your vehicle's finish without scratching. Spray on, wipe with a plush microfiber towel, buff, and the car is clean. Most waterless car wash products don't contain any protective properties and will not leave a shine that a true Auto Geek is satisfied with. Follow up with a spray wax so you can sleep at night.
Nick's Favorites:
- BLACKFIRE Wet Diamond Waterless Wash
- Optimum Opti Clean Cleaner & Protectant
- Detailer's Waterless Auto Wash
The translucent yellow lines running parallel with each other show the path of my swipe. As you can clearly see, the area where I swiped my finger is cleaner, but not clean. This is because there is a film of dirt on the paint. If I were to use a quick detail spray at this point on Bob's Vette, I could potentially scratch the finish.
What does a exterior QD do that an exterior Spray Wax doesn't do?
When to use which? TIA
That's why I got UWW+ to clean and d156 to spruce it up....I'm slowly migrating away from carnubas and going with synthetics only
Quick Detailers can also be used as a drying aid, to add lubricity to a drying towel and also help remove any water spots that might have dried on the car.
There are some spray waxes that can also be used as a drying aid, but not all.
I have used AMMO's Hydrate as a drying aid in the past. I am in my initial stages of trying out WW - 3D WW and UWW+.
Larry's stuff is very expensive , its more for the car owner, not the pro detailer.
As a pro kind of hard to fork up the cash for his stuff , I'm sure hydrate works great tho.
