cshamilton
- Aug 6, 2013
- 400
First, I want to say that I was just playing with this idea; I definitely used the wrong material for the tubing. You really need some latex tubing and I found some online being sold as "surgical tubing." My local Lowes has some, but it's in the 3/8'' sizing: too big for this application. If you use latex tubing, this will be a very nice addition to your spray bottles, and you won't have to use a $4 part as the "weight." On to the good stuff:
Using my interior cleaner this weekend, I got pretty annoyed when trying to reach the bottle upside down under certain spots. To get the coverage that I wanted. I needed an aerosol-style bottle that would spray upside down. This is what I came up with.
Hope it helps!
Scott
" and yet a true creator is necessity, which is the mother of our invention. " -Plato
My favorite spray bottle:
These are the parts that you'll need. Note the aside above: you'll need to use latex tubing for this. I happened to have a piece of Poly tubing that was the same size as the original, 3/16 ID. You can trim the original tube if you'd like; I prefer to preserve the original in case of a return to factory form. The vinyl that I used is not quite flexible enough. The weight that I used is a 1/8" hose barb. Using latex tubing, you'll be able to substitute this for just about anything, glass beads come to mind, possibly even the original strainer from the GG sprayer.
Trim the tubing to match the length of the original tube.
Remove the factory tubing from the sprayer.
Insert a small piece of the new tubing, preferably latex, into your original (or original sized) piece.
Trim the original or original sized tubing to an inch or two, and apply the weight. I used a hose barb on this one.
Gently push the poly tubing back into the sprayer.
This is the final result. This is what you're looking for. The ability for the "draw tube" to react to gravity- the same way product inside your spray bottle will. This will help with any presoak applications on lower panels of cars, interior cleaning in tough to reach spots, pretty much anything that you may need a spray bottle to work upside down.
Hope it helps!
Scott
