Quick question on sealant curing time if the weather get nasty
keepitclean
Looks like I will have a car to do this week and I'll be able to detail it in doors. I plan on a one step process and look to seal it with Klasse AIO. This is a tough last step product which will have some durability with the car sitting outside all the time.
So....how long can I wait before Klasse AIO needs to seal/cure and come out of the garage. Wednesday is suppose to be a little wet and dreary and just worried about exporting the car to moisture too early.
Thanks..
From my use of KAIO...
It doesn't need to cure, per se...especially if you immediately follow-up by applying
the other half of the "Klasse Twins": Klasse High Gloss Sealant (KHGSG).
That's when curing becomes more pertinent, IMO.
That's usually a 12 hours (minimum) time period for KHGSG.
KAIO seems to lack the toughness and durability of a
more dedicated LSP like its complimentary-"Twin": KHGSG.
But:
If you're not going to immediately apply KHGSG...
My advice is:
Why not keep the KAIO as dry as possible, for as long as possible.
Treat it as if it was KHGSG.
Once applyed to the paint work wait atleast 45 mins to buff off it wont be fully cured until 8 to 24 hours depending upon your enviroment if you have trouble removing product just sprit two spray of water...good luck
