Desertnate
- Aug 5, 2013
- 6,187
- 233
I had a little free time and some dirty all weather mats in all three of our family vehicles, so I drug out the cleaner and all my mats and went to work.
None of the mats had seen anything other than a vacuum cleaner since last fall, so they were pretty dirty. Because of the levels of dirt, I actually hit the MDX front mats and the Weathertechs with the power washer first, but only with water.
What did I think of the product? It's OK. Application is easy. Spray it on a dry mat, scrub with a soft brush, and then wipe off with a MF towel. Cleaning ability is quite good, actually.
Where I struggle with the Blackfire Mat Cleaner, is the appearance after your done. Being a dedicated product that supposedly has a protectant built in (and maybe a bit of a dressing) I was hoping to see some darkening... something. On my OEM BRZ mats that are a very soft rubber, there was nothing to see at all. Ditto for the MDX mats even though they are a harder material, but still on the soft side. The Weathertech liners did look a touch darker, but I couldn't tell if it was something the Blackfire Mat Cleaner left behind, or if it was simply because they were really clean.
I bought the mat cleaner in the first place out of a hope it would offer a little something I wouldn't get using an APC like I have in the past. Now, I'm not sure they do. In a few months, I'll use it again and do a full side-by-side test.
Here are some pictures of the results.
Sent from my Pixel 7 using Tapatalk
