Quick review of HD Express Quick Wax
haris300
I'm a big fan of HD Car Care products so I was pretty excited to try out their Express Quick Wax.
Long story short, sprinklers left my Miata with some nasty water spots that I needed to remove with CarPro Spotless. I wanted to follow up with some kind of protectant since Spotless is acid based. This car is going to a new home soon so I'd like it to look its best before it leaves.
Since I was going to be washing the car to get rid of the water spots, I decided to try out HD Wash. I liked this shampoo very much. Great smell, super slick, and plenty of suds that stick around in the bucket for the entire wash.
As you can see, no need to add additional shampoo halfway through the wash. I did use a foam gun though to make things a little more fun.
I used plenty of Spotless all around the car since there were water spots everywhere. One of my favorite CarPro products (next to Hydro2 and CQuartz of course).
After a final rinse down, I dried the car with a Master Blaster and got to applying the Express Quick Wax.
This product is not a traditional "wipe on walk away" spray wax. Its consistency is more like that of a glaze, and it leaves behind some decent protection, similar to HD Poxy. It has the ability to fill in light defects and really makes paint pop.
Although the directions say you can apply with a microfiber towel only, I found this method to be very messy and decided to use a foam applicator instead. The spray nozzle can splatter product everywhere if you decide to spray directly onto the paint. I chose to spray it on the applicator instead.
Product wipes on easy and hazes up quickly. Easy to wipe away. Pretty straight forward stuff. Treat it like a glaze and you're in business.
As you can see, after about 20 minutes of going around the car and applying product, the paint looked nice and glossy. Application was a breeze and the car looked beautiful. Very slick to the touch too.
This stuff gets my seal of approval. Not a bad product for 11 bucks.
Thanks for the review.
So this product is somewhere in between a spray wax and a liquid wax? You need to let it haze before wiping off?
No you don't need to let it haze, but as the OP stated it spreads best with a foam applicator, but then just immediately buff off and you're good to go. First time I used it on my wife's black Golf I was amazed at the gloss level it produced.
Nice review. Express is nice. I got a sample of it over on Autopia when 3D was sending out products for review. The little pump sprayer sprays a good amount to use it with a microfiber towel.
Thanks guys! I wouldn't really call it a spray wax in terms of consistency. It's more like a glaze with a spray nozzle. It's thick in consistency, not watery.
Correct, no need to let it haze but it seems to haze up regardless in between application and wiping (unless you're really quick ;))
It is exactly like a glaze with one important difference...it protects like an LSP!...so the glaze haters out there...you no longer have an excuse to avoid such a product. If ever a product was misunderstood because of its name...its this product. It really is exactly like a glaze with that gorgeous glaze look and filling ability...but can be a stand alone LSP.
This stuff is pretty thick. Have you tried in on a hot day?
Put it on super thin one panel at a tine...remove immediately, then go into next panel if working in sun.
Oh yes, the name did get me at first. When I think quick wax, I think a watery liquid spray. I might test out its ability to hide light defects tomorrow evening. I'm curious as to what the durability of this stuff will be like as well.
It was in the mid 80s late in the day when I applied it. Pretty warm but not mid day Texas heat kind of warm.
Outstanding review. :dblthumb2:
I'm a big fan of this product as well. Talk about easy to use.
any idea of longevity?
Not entirely sure, but I found this in the product description:
"HD Express contains the same montan wax, albeit a less concentrated blend for detail spray purposes, as 3D HD Poxy, making it an ideal choice to extend the wax protection already on your vehicle. HD Express can also be used as a stand-alone paint protectant if so desired."
I don't expect stand-alone longevity to be all that great, but this stuff is probably a great booster for if you already have HD Poxy applied.
Approximately 3 months. I've attended many a car show and I can honestly say my car never looked better than when I applied this product...and I've tried many glazes, waxes, and combos over the years. HD speed coupled with HD Express is an absolute killer combo for the money.
:xyxthumbs::xyxthumbs:
I usually use UWQ and have no problems if it gets on the trim (wipes off easy, no white spot)..how does this compare?
HD express in nothing like UQW...again, its more like a glaze than a spray wax. You apply it with a foam or MF pad. Calling it a spray wax honestly...is a stretch. It doesn't stain trim.
I have the 3D version and I love it! I have used it on a care getting ready for a photo shoot to make the paint pop, and I have used it as the last go around on an express detail, which I think is what this product is truly made for. Durability should not be the deciding factor when using this. I think this is a great, show day product as well, especially one where you drive to the event.
HUMP
