Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
Real difference between SONAX EX 04-06 and SONAX Perfect Finish?
No time to type out answers for one set of eyeballs. I appreciate it when people take the time to type out their questions in an e-mail or some other contact method but hey... why not join this forum and post them here?
I'm going to answer them here anways.... it's free. (joining the forum), and if you can think and type it's easy. If you're on your phone get the TapaTalk app. I use this App all the time, works great.
Hello mike,
what's a real difference between sonax perfect finish and sonax ex 04 06.
I know Pf was a project to work on with rotary and ex to random and d.a polishers.
That's a question,to detaling projects,what's the best choice to make a flawless finish ?
Thanks mike.
Enviado do meu iPhone
You answered your own question but here you go...
SONAX Perfect Finish is a finishing polish for ROTARY Polishers. I've used it to finish out with the FLEX PE14 and it works GREAT!
We had a team use it to finish out using ONLY a rotary polisher on our TV show and it WORKS GREAT!
Of course you NEED to use a SUPER SOFT JEWELING FOAM PAD to jewel with and you need more than one pad. If fact I'd recommend one pad per panel if you're a pro, otherwise you'll be doing hack work.
SONAC EX 04-06 is a polish for use with orbital polishers and it works great too...
Hope that helps...
:dunno:
Hello mike,
Thanks mike.
Hope that helps...
:dunno:
