TMetzinger
- Mar 1, 2010
- 1
I'm posing this because I'm a detail oriented engineer and I'd like to get things down to a repeatable process...
I use a two-bucket method - I've got two 5 Gal buckets, both with grit guards, and I fill up the rinse bucket with probably 4 gallons of water. Then I mix up the wash bucket, and this is where it gets unclear. Ratio of wash to water is 1 Oz per Gal. But, am I trying to take a gallon of water and make a bucket of suds? Take two gallons of water and make some soapy water with suds on top? Three? Keep in mind that the top of the grit guard is probably at the 1/2 gallon fluid level.
Reason for all this overthinking is to figure out how much soap I need per wash and then I can figure out how often I need to order a new batch of wash shampoo.
Best wishes,
Tim
Best wishes,
Tim
