Can you guys recommend a reliable washer that doesn't cost a fortune?
I am not a pro detailer so I don't need very high end model. I need just intermediate washer that clean engine and remove dirt on door.
I mean pressure washer. What do you think of sun Joe brand?
Sent from my SM-G965W using Tapatalk
SunJoe is alright but I think they use non-standard fittings so if you plan to upgrade parts of it (hose, gun, or add quick disconnects) it may be complicated to make it work.
I think Ryobi and Greenworks are cheap and use standard fittings. Karcher K1700 cube is something people like to and cost just over $100.
When looking for a machine try to get one with as much volume output as you can. For washing cars, volume is more important than high pressure. A 2gpm 1000psi machine would be way better than a 1.2gpm 1800psi machine.
I just got the Karcher K1700 Cube. The hoses and nozzles remain in the box, unopened. Instead, I went full-boat with OG upgrades. Now, the pump is the cheapest part of the entire setup. However, it's the only part with a 3-year warranty. Zero leaks so far, and pretty dang good performance. The upgraded Mosmatic gun/wand, inlet/ourlet hoses and stainless QD fittings make the entire setup a real quality way to work. It's overkill, for sure, but all that gear can easily transfer to any other washer I but in the future.
