Recommendations for oxidation remover
Sonic Pilot
Hello guys,
So, I've got a 2007 Cadillac DTS, black factory paint that is experiencing what I would call moderate to severe oxidation. I am looking for recommendations for products that could effectively restore the finish (if at all possible).
I did notice that Meguiars offers an oxidation remover. However the packaging specifically says it is for fiberglass/gelcoat finishes. Marine grade obviously. Not too sure this would be appropriate for an automotive finish application.
I have tried Griots Fast Correcting cream with an aggressive foam pad and have only been able to temporarily reduce the appearance of the oxidation. After a brief time, the oxidation returns. My guess is that any oils in the Griots polish are causing the temporary reduction in the appearance of the oxidation and not truly eliminating it.
So, can anyone offer a recommendation for a product (or technique) for restoring the oxidized finish?
Lastly, how can I tell if its only oxidation, and not clear coat failure?
Thanks in advance for any tips!
Don’t use that oxidation remover. It’s for boats not cars.
After you used the Fast Correcting Cream, what did you use to protect the paint?
Would like to see pics of your Cadillac.
Did you apply the fast correcting cream by hand or machine? Have you successfully polished paint before? Usually when clear gets "oxidized" like that, it's incipient failure, but I guess we've seen a few times on the forums where someone brings one back.
I applied the Fast Correcting cream with a DA and a foam cutting pad. I then topped it with Blackfire Black Ice.
I was surprised how the oxidation returned after about a month or so. I initially thought I was eliminating it but absolutely not.
So did it look good after you polished it? Or only better than it did? Is it uniformly oxidized or only in some spots?
The oxidation seems to be "random" patches, fairly uniform in their appearance and most noticeable in areas frequently exposed to direct sunlight.
Yes, the climate is extremely hot and sunny. Its no surprise that the oxidation is occurring, I am hoping there is an effective way to eliminate it.
I think the issue is hot sun/black paint/weak protection.
I don’t have much faith in any Montan Wax. The ones I’ve used have offered weak protection that didn’t last on daily drivers parked outside.
If I were you I’d compound again, followed by a finishing polish such as Meguiars M205 or Perfecting Cream. Then protect it with something more sturdy, maybe step up to ceramic. Cancoat is very user friendly, just make sure to use Gyeon Prep.
Hence the Sonic Pilot...funny when Eldo said AZ I started typing that I used to work with someone that was stationed at Nellis and had a Caprice that he had from new that was only about 5 years old then that the rear deck was all cracked from that NV sun. Sounds like it's time for a wrap--you can tell your friends you did it to reduce the signature of your ride.
Did a lot of flying for Nellis as a DOD contractor. Loved every minute of it!
Sounds like clearcoat failure to me.
Yep! That's what it sounds like to me too.
While you can improve the appearance in the short-term, the failure process has already begun and whatever improvement you make will be limited by that fact. The improvement will not be long lived, and the finish will continue to degrade at a faster rate than a more sound finish.
That accelerated degradation rate is the reason that any improvement you can achieve will not last very long.
Janet Air? In that case, why not just bring home some reverse engineered PPF and never have to worry about it fading again.
No, not JANET. I'm a helo guy. Flew helicopters on the ranges for many years.
