4mulafastech
- Mar 12, 2012
- 9
I am looking for any recommendations on a durable, over-the-counter coating that works good on brake calipers. I have a 2018 Camaro 1LE with red painted Brembo calipers. Thanks!
No recommendations, but congrats on your purchase of one of the best performance cars. Exotic car performance for 1/4 the price![]()
C5 comes with I believe 4 applicators. I forget since the last time I used it on a set of wheels a few weeks ago. Essentially one for each wheel. You could probably get away with using 1 or 2. If you need more I would look into getting some suede applicators from CarPro or the Gyeon. I recall reading that C5 is rated somewhere around greater than 500 degrees or so.
Gyeon Rim comes with everything you need in the package as well and Jeff from Gyeon stated it has temp tolerance of 1400 degrees per his write up
How To: Protect Your Wheels with GYEON quartz Q2 Rim
CarPro DLUX claim a range exceeding 800 degrees. This also comes with everything you need. I got 1 year out of it on my wheels with little maintenance.
The only thing you need is some sort of prep wipe or IPA wipe to prep the surface.
