AeroCleanse
- Nov 17, 2008
- 2,422
I thought my arm speed was good, then I video recorded myself polishing for my business. Looks like I am moving way too fast with the arm speed.
One inch per second is the norm.
Just measured the door on my Yukon....
Approximately 48"x36"
At 1" per second
50% overlap
6 passes
I get 1 hour, 48 minutes
Someone check my math
The 50% overlap makes the calculation slightly more difficult
Well you would work in a 24" by 24" section (for math's sake) with a 6" pad for ease of math.
Public quick math shows 1 minute 30 seconds for a single pass in one orientation.
Not saying it isn't the referred standard
Not saying you are going faster or slower
Next time you are using tape for a 50/50 shot, mark it in 1" increments, you might be surprised
6" pad
12x12 section
50% overlap
6 "Passes" (up down & left right)
Takes over 7 minutes
I am always surprised at "Arm Speed Creep" during a polishing session and have to continually remind myself to moderate the pace
Correct, and assuming the pad cover's 6" x 6" which would be a square but adding in the dimensions of a circle was too much for me so it would actually take longer.Your calculation is for zero overlap, right?
36 seconds/pass in your example not sure how you came up with 7 mins.
With rupes and flex 1" second is too slow imo, pc yes need to move slow
Sent from my Alien ship
In the long run:This is the video of my polishing. I swear it looks slower when I am doing it. Then I watch myself and I seem to be going a lot faster.
https://www.youtube.com/watch?v=4ZjAJEZ4tAM
In the long run:
If you are getting the desired results from your polishing-techniques; tools (*a long-throw RUPES in this case); pads; along with your choices of polishing-liquids...I say:
What the dickens does it matter what your arm-speed is!!
In the long run:
If you are getting the desired results from your polishing-techniques; tools (*a long-throw RUPES in this case); pads; along with your choices of polishing-products...I say:
Theoretically speaking...(when using a PC 74724XP):BTW, my math fails to include the throw of the machine so the 6" pad is actually polishing more than 6" with each pass
