REMOVAL of Glass Scratches with CarPro and a Griots DA
swanicyouth
About 8 months ago I tried to correct my badly scratched windshield with a PC 7424, CeriGlass, and Lake Country 5" Glass Polishing Pads. The windshield is original on my 2001 Nissan Pathfinder. I bought the vehicle used, but it's still the factory Nissan glass. Twelve years of running windshield wipers on dirty glass left the windshield in bad shape. You can see my original attempt here:
http://www.autogeekonline.net/forum/product-reviews/49160-ceriglass-my-experience.html#post660779
To sum it up, while my first attempt did clean the glass up, it left hazing, tic marks, and micro marring on the glass. As time went by, it became more annoying and noticeable I was considering replacing the windshield, but I really wanted to learn how to fix glass, as wiper scratches on a daily driver are probably inevitable. Why did my first attempt to fix it fail? Was it:
1. CeriGlass is no good?
2. The fault of the LC Glass Pads?
3. That you need a rotary to remove scratches from glass and the 7424 wasn't cutting it?
4. My fault?
5. A combination of all the above?
For the past 8 months or so, I've been trying to figure it out. The problem is, there is a lot of info (and products) geared towards cleaning and removing water spots from glass, but not too much info on how to remove defects or scratches from a glass windshield.
Here are some pictures from both my original and latest experience with glass polishing
Here you can see some blur and wiper scratches looking out from the inside. The tic marks / micro marring I was not able to capture with my camera (IPhone 5):
More wiper scratches:
This time I picked up a new DA, a GG6, and figured the increase power would help. Also, I decided not to use LC Glass Pads, as the old ones started falling apart while I was using them once they got wet. Since CarPro makes CeriGlass, I figured their pads would be ideal. Also, they come in 3" & 5". The CeriGlass I received this time seemed more lotion like than the product I bought 9 months ago. Also, the color was a yellowish off white. The older CeriGlass was like White Out. Here are the two to compare :
As soon as I got the CarPro glass pads, I realized they were different. They were not just re-branded Lake Country glass pads, as I suspect a few others are. In fact, they are significantly different. CarPro advertises them as rayon glass pads, I'm not sure what the LC pads use for the cutting material, but those pads are very stiff, almost cardboard like with no cushion. I found that the cutting material on the LC seems to be attached to their pads with some sort of adhesive. When it gets wet, they start to shed cutting material.
Not so with the CarPro pads. Actually, when this was all done and the pads were washed, the CarPro pad looked like new still. I was able to do this whole job with just one CarPro pad of each size.
Here you can see the CarPro pads (thicker with red Velcro) vrs. LC's glass pads:
The CarPro pads are thicker, flexible, and have more polishing material (rayon) more densely packed on the face. I was starting to think this actually may work, as one of the main issues I had previously with the LC pads is the polishing material coming off the face of the pad when you spray them with DI water while polishing (after a while).
CarPro 3" Pad
Polishing with CeriGlass makes a huge mess, as the polish must be kept wet through frequent sprays of DI water on the glass. I found no matter how hard you try to cover up the vehicle, washing the car will be required after you are done machine polishing with this stuff.
Towels were taped to the hood and the roof. Also, paper was taped to the side glass. The good thing is, CeriGlass is water based, so it comes right off with the spray of a pressure washer.
A picture of my set up:
From L to R: GG6 DA I got from AG just for this project with 3" LC BP & 3" CarPro Glass Pad, LC 5" Glass Pads, Meg's Mild Mirror Glaze Clay, CarPro 6" & 3" Rayon Glass Pads (red Velcro), DI water in spray bottle, isopropyl 25% in a spray bottle, CeriGlass Polish, Prima Clarity Glass Cleaner, and CarPro Fast Glass cleaning cloth.
The Process:
1. After covering up as much of the vehicle as possible, I cleaned the windshield using Prima Clarity. After that, I clayed it using the Meg's clay. Not much came off. Then, I wiped it all down with a 25% solution of IPA. Interestingly enough, I had the window coated with the new Pinnacle Glass Sealant. Neither the clay or the IPA seemed to remove any of it. I thought the clay would for sure, but it didn't touch it. Windshield was beading after as well as before cleaning.
2. After cleaning, I decided to start with the 3" CarPro pads on a section with the worse scratches in the bottom portion of the wiper path. This is where I started:
While the scratches don't look too bad in the photo, they are MUCH worse in person. You could just barely catch your nail on them if you tried. I decided to start with the small pads and work on a small area, about 8" x 14". I began by priming the pad and placing about twice the amount of polish on it than usual for paint polishing.
I turned the machine on about speed 4.5. I was able to make ONE pas before the polish started to dry. However, I was prepared for this and had my DI water in a squirt bottle at hand. I soon realized that I was going to have to spray a squirt or two of water on the polishing surface after EVERY pass to keep to polish "wet".
This is possibly where I may have went wrong last time. This is nothing like polishing regular paint. The polish dries extremely quickly on the glass surface. It's very important (I found out) to NOT let the polish dry at all while buffing. This can get a bit difficult. As your constantly one handing the buffer to reach for your spray bottle. Also, the pads have little backing material between them and the backing plate (they are as thick as two stacked pieces of cardboard), so this causes a lot of vibration and make the polisher a little hard to control at times.
After a few section passes, and several squirts of water, I decided to kick the polisher's speed up to 6. I was using very slow arm speed (about 1/2" per second) and putting a lot of downward pressure on the polisher. Three things I noticed fairly quickly about the process/ products:
1. The pads did not heat up at all, in fact they stayed cool. This was due to the constant spraying of water to keep the polish "wet". Once the pads got saturated with polish and water they became very flexible and you were able to bend them in half if off the backing plate. The pads would stay damp, but the polish would dry on the glass surface. This is contrary to the LC pads, which always stayed firm.
2. The CeriGlass has an almost an infinite work time when spraying it with water. To complete the whole windshield I ended up using less than 1/8 of one small (4 oz?) bottle of CeriGlass and likely could have used less. This is contrary to my last attempt, where I kept adding more and more polish as it would dry (and some water) and ended up using over half the bottle for one attempt.
3. The "overheating issue" some have experienced when using the Griot's GG6 DA Polisher is not cause from heat transfer from the polisher motor or mechanism. Any heat is directly transferred from the buffing pad to the backing plate. The machine itself creates little if any heat. This became significant because often times during this session I was running the polisher on SPEED 6 with lots of down pressure for up to 20 minutes strait without shutting the polisher down. I kept touching the guard around the spindle mechanism and it stayed room temperature.
After about 15 minutes of buffing that small area, I stopped to check my progress. I was really happy to see the scratches were 100% gone and the glass was optically clear - no hazing, tic marks, micro marring - just clean, clear glass.
Before:
Same Area After:
After the initial spot, I decided to switch over to the 5" CarPro pads, as it took quite a while to do that small area. Also, I was running the buffer at full speed and it sometimes became difficult to control and keep grabbing the water bottle, since the pads have little cushion. This is where the bale handle on the Griot's Polisher actually came in handy.
To do the complete windshield, I ended up spraying almost a full liter of water. I probably used less than 1 ounces of polish. The total polish time was probably about 2.5 hours, where, the buffer ran at full speed for 20 minute increments without breaks under a lot of downward force. The Griot's machine performed perfectly.
I was able to remove pretty much all the scratches and tic marks from the glass just from repeating the process over and over. In fact, I feel I would have been able to remove even deeper scratches then were present with more polishing time. Unlike paint, with glass you don't have to worry about strike through. There are still some pits in the glass and they can not be removed.
Some pictures of the process:
Here is what I learned about glass polishing with this combo:
1. The CarPro pads are like night and day compared to the LC glass pads. The CarPro pads don't fall apart after prolonged buffing in the wet polishing slurry. They are thicker, and they have denser polishing material on the front. I would recommend the CarPro Rayon Glass pads to anyone trying to remove defects from glass. Same thing with Ceriglass. Both are first rate products that really have no competition in my mind. While there are a lot of "water spot removers"; I don't know of any other available glass products that claim to remove scratches from glass, no less one that can actually do it.
2. You do not need a rotary to remove scratches or defects from glass. In fact, a DA could be better, as you will not have to worry about heat build up or causing any type of holograms in the glass - assuming its done correctly.
3. Adding water to Ceriglass (keeping the polish "wet") while polishing is essential to success. Plan on spraying after every section pass - it dries that fast. In fact, I'm convinced dry buffing contributed to my hazing the first go around. This can not be stressed enough. You need very little polish and a lot of water. This is opposite to regular paint polishing, where you may add a single spray of water to a compound to boost the work time. Also, you get more done by adjusting your process. When doing a single pass, I would back up and go over the line I just worked, since the polish was still wet their. Once I was at the point to add more water on that line, I would move to the next pass.
4. Working with the 5" CeriGlass pads is much easier than the 3" pads. Nothing is wrong with the 3" pads, its just a function of their size - its hard to control the machine with the 3" pads, since there is little flexible interface to the pad, the machine sometimes wants to walk or tip. Moving the buffer with one hand did not work well, so I was quickly hugging between the water bottle and keeping both hands (and a lot of downward force) on the polisher. The 3" pads would be good for small areas of glass and corners where the bigger pads won't fit.
Here are some pictures of the glass when finished:
From the inside looking out:
After I was done I did a final clean on the glass with a CarPro Fast Glass Towel:
This towel is very thin (140 gsm) and kind of reminded me of a thick white shop towel or a square of bed sheets from a cheap motel. It's meant for removing any streaks or haze that is often left after cleaning glass conventionally. You use it only with water. It works very well, much better than a regular towel. While any other towel wet with water would leave rows of water streaks behind, this towel leaves what looks like a fine mist of water that instantly evaporates. Anyone who struggles getting the inside of the windshield perfectly streak free should get at least one of these for 5 bucks from CarPro USA. They also work great on your bathroom mirror.
After I was done with the glass I rinsed down at the local coin-op and did a waterless wash with Pinnacle Liquid Crystal Waterless Wash:
The wheels were cleaned with a Montana Boars Hair Wheel Brush, a Daytona Brush, and Chemical Guys Sticky Wheel Cleaner. Then I spray waxed with Flitz Wäxx Speed Wax Spray - a great spray wax that doesn't streak - even on glass. All the glass was also waxed this way (except the windshield). This vehicle has a lot of glass!
All done:
Thanks for looking and feel free to ask any questions.
Great review! I got my CeriGlass last week but didn't order any pads. After reading this, I am definately going to order the CarPro pads first. Its kinda sad that you get better direction from AGO than from the manufacturer. Or, its just a testament of the available knowledge here. Thanks for all the great info! :xyxthumbs:
Excellent and very detailed write up! Thanks for taking the time!
Great review and just in time. I picked up some Ceriglass but had not planned on using the special glass pads since I do not really have buffer marks, I am just trying to get the glass very clean in order to use the glass sealant.
What was your work area for the 3-in and 5-in pads? It looks like you at least worked it vertically (hood to roof) and at least 5 inches horizontally.
How much did you apply to the pad at the first pass? Also did you prime the first time around or just add a few drops and go at it.
Sent from my iPhone 4S using Tapatalk
Thanks for the review..very well done
I think I will try out your product choice
I dont see the carpro glass polish pads in the AG store..what are they listed under?
Superb review and an amazing finish.....:props:
I did a CeriGlass test in September and used Griot's glass pads. I had great luck with this combination and the results were spectacular! :props:
Great review and writeup! :dblthumb2:
You have to get them from Corey at CarPro USA. Make sure to get a Fast Glass Towel for 5 bucks they are great. AG should sell the pads and towel, as both are far superior to other offerings in my opinion and are class leading products.
The thing is, your work area can be as big or as small as you like since you constantly have to spritz the surface with water. That pic doesn't accurately show my work area, as I made a quick final pass over areas I didn't work.
A good work area with the 5" pads is 1/4 a windshield; 3" pads 1/8 a windshield.
I primed the pad with polish completely. Added just enough so it wouldn't sling. Them I added polish directly to the glass, about a 6" line to do 1/4 a windshield. However, it all seems to come down to how much water you spritz. I could have done 1/2. A windshield with the same amount.
Thanks for the reply...I too wish we had those here at AG
I was ready to load another shopping cart
Excellent review! Very well written and includes meticulous detail. I appreciate it tremendously. I too have struggled with some hazing trying to remove some scratches on my rear windshield (put there when the foreign tags were badly removed, resulting in many 'brillo' ovals at the left and right corners of the windshield.) I bought the Ceriglass here at AG and tried it with my Griots DA. I too had a problem with the drying... as you say, a much more different technique is required as opposed to regular paint polshing/correction.
Interestingly, I had better results using the Ceriglass by hand, just a much more laborious process. I've recently gotten the 3" and 5" Carpro glass pads and now with your write-up and recommendations, I feel confident that I'll finally be able to remove those scratches. This is why I continue to monitor AG's forum, you can pick up some really good (and much needed) advice.
And thanks for confirming the tremendous reviews I've read about those Fast Glass towels. I'll be sure to pick some of those up.
Hey,
This is one excellent write up. Usually when I see reviews which are this long I just scroll down rapidly, but you did manage to get my attention all way through - Kudos!
One thing that did bother me (about the process) was that it took you 2.5 hours to do the windshield alone. I mean - 2.5 hours?? Seriously? I very well may be missing something here, but I would like to believe CarPro did not intend of creating a product that would demand this amount of investment by the user?
In any case, thanks for sharing your great tips!
Fantastic write up! The results are night and day! I need to give those CarPro glass pads a shot. I have only used the LC glass cutting pads and TBH wasn't entirely thrilled with them. I had no idea the CarPro pads were so much thicker... Thanks!
Regarding time spent: It really depends on what the condition of the glass is to begin with and your desired end results that will determine how long it's going to take. If you are simply removing etched water spots you might only spend about 5 minutes per window. Removing wiper marks, haze, and scratches takes MUCH longer.
I've gotta try this, but I've got some pretty funky scratches.. How deep of a scratch can this correct?
I'm impressed with the results shown here, with the products used. 2.5 hours doesn't surprise me at all. lol
Polishing scratches from glass is difficult to say the least, even though some professional systems claim it's fast and easy. I've used a couple very different systems and have researched plenty of others. I've done quite a bit as a side service to my windshield repair business for car dealers, removing scratches, water spots, etched marker writing, etc. It's not something I like to do, though. There is a limit to the damage that can be fixed which a customer never likes to hear, and sometimes you don't know exactly what's possible so some jobs end up being a wasted effort, while others come out better than expected.
There is a reason why most glass shops don't do it.... especially on cars, because it's generally not cost effective compared to replacement. The glass polishing market is in high dollar commercial jobs, where the glass is a lot more expensive. The guys who do it commonly charge $60-100 an hour and sometimes more... a lot more if they are bidding a big job.
But for a DIY or working on a classic car, etc where a replacement glass is expensive or a last resort... it makes sense to take time to try to restore it. Severe damage, deep scratches or pitting... may be possible to fix but would probably require a more aggressive method such as one of the systems that uses abrasive discs to "sand" the surface and then bring it back to a clear finish.
It takes a while, I'm sure others can do it much faster. You could use the set- up to remove water spot or glass contaminants much quicker, but that would be overkill IMHO. As, with the before prep and clean up it takes a bit of time and work, you would likely be better off using the Pinnacle Water Spot Polish for glass. It's impossible to use this polish without slinging it everywhere Reason being, it goes from the consistency of water to dried White Out in no time, so a lot of times you are buffing with something the consistency of water.
Excellent review! Very well written and includes meticulous detail. I appreciate it tremendously. I too have struggled with some hazing trying to remove some scratches on my rear windshield (put there when the foreign tags were badly removed, resulting in many 'brillo' ovals I bought the Ceriglass here at AG and tried it with my Griots DA. I too had a problem with the drying
You will likely be able to fix it. The secret is to keep spraying water and keep the polish wet. You don't want to rinse it away, but you never want it to get pasty or dry. A lot of times I was buffing with a very watery slurry. You want to spray enough to keep it wet, without having the polish all run down the glass. If you do this, you can work it for a very long time and remove some pretty noticeable scratches. Also, the pads or glass won't get hot, as the keep getting cooled by the water. You will also need to re-wet the polish to remove it when you are done.
If you have a Griots, you may want to keep the bale handle on, as I know a lot of guys remove them. You won't necessarily use it while buffing directly, but it came in handy to kind of lean my wrist on while my hand was on the polisher head to grab to water bottle. It really did take out all the scratches (pits will remain).
Believe me, I was as surprised as anyone how well it worked. This isn't the first product it took me a second try to get right.
this day & age with all the new pads and different products available (and keeps evolving), there doesn't seem to be much of anything that the DA isn't capable of taking care of. nice write-up, thanks for taking the time to share...
Wow, thanks for taking the time to do this. Just the info i was looking for, since my first attempt at polishing glass didn't go as well either.
Great write-up, detailing the process taken, usage of the products, and results achieved clearly. I'm bookmarking this in case I ever need to remove scratches from glass :)
