Yes it is necessary IMO to remove the old layer of wax that way the new coat of wax can bond to the paintwork , and not the remains of the wax also dawn may strip your lsp but in the near future consider something like Chemical Guys Citrus Wash & Gloss or Chemical Guys Citrus Wash and Clear to do your stripping
Did some quick reading on the CG soaps you mentioned. The citrus clear says it's wax safe, but the wash and gloss says depending on the dilution, it can be a regular soap, or a wax stripper.
When stripping a wax with this soap, can I use a foam cannon to do it, or does it require a mitt/bucket to do it properly? Or both?
So what's the stripping dilution of CGCWG with the cannon? If my math is right, for a 32oz cannon, that's 1/4 oz of soap?!?
Naaaaaahhhhhhh....
At least 1 oz no?
Your not including the water from the pressure washer. You have to see the total volume your set up ejects to empty the bottle. Once you figure that out, that is the total volume of water your trying to dilute your soap in. So, if you spray your bottle into a 5 gallon bucket, and you measure the bucket is full with 3 gallons, you want to use. 3oz of soap in the bottle (1oz/gallon). That is the dilution the soap will hit the car at, or panel impact ration as Bilt Hamber calls it.
Or you could time it, if you know the gallons per minute of the pressure washer. Then, just add the volume of the the bottle.
However, I don't believe CGs Citrus soaps strip much at any dilution.
Mike, your response was an eye opener, and now it's clear that it's a good rule of thumb to remove old wax before applying a new coat. Those photos really make it clear!
Details:
2013 Hyundai Santa Fe 2.0T
Daily Driver
Black Metallic paint
Always outside, no cover or garage
And keep it up with optimum spray wax.
I'm planning on doing a wash, nanoskin, wolfgang SR twins, and max wax as a lsp initially.... Will switch to collinite 845 + double coat for the winter months.
Getting those last pieces of info before spending $500 ish on my initial order....
With that said, and since I have a PC,
what's a good AIO/polish without correction ability to aid in this step?
XMT 360, Menzerna 4500.... Or?
Both XMT 360 and Menzerna SF 4500 have the ability to abrade the paint, i.e. they offer correction ability.
The SF 4500 is an Ultra Fine Cut Polish and would actually be a great option to maintain your BLACK car's finish.
Done. Practice this each time you want to restore that "just detailed look", at least to the hood and tops of fenders, (things people look at), maintain with the Optimum Car Wax in-between this process after washing or wiping clean.
- Wash
- Clay if needed (Nanoskin)
- Machine polish with the SF 4500
- Seal with something
Also, anytime a person clays or uses products like the Nanoskin products they should really already plan on doing at least one machine polishing step to remove any marring left by the claying or other mechanical decontamination step. Especially on black paint. I do.
Mike... again I really appreciate the help on this. I know from your detailing experience, and large amount of videos i'm getting good advice.
I only tossed up the thought of 360/ Menzerna 4500 as examples (from what i've been reading). I don't really want to be effecting that clear coat 3-4 times a year... i'm hoping to really only have to do a correction once every two years if I can get away with it. I thought 4500 as it was the least aggressive, and thought it was more of a "gloss enhancing" product. Are there better products that I could use without the correcting ability? Would a glaze do it?
Any specific examples would be great. The reason I was thinking more towards the soap doing the work of stripping the lsp, is that the pads on the PC would get "gummed up" with lsp product as i'm removing it. I guess a 1-2 punch would be the best for this.
