Prepping car for winter but having difficulty finding a thread that tells me if I need to do anything special to remove this?
Thanks,
Howard
If you're still seeing strong beading then a strong prep wash and clay barring will probably not be enough to remove the remaining sealant & wax. You could go over the car with a paint cleanser and a black or white pad if you don't want to remove clear coat. Or you could go over the car with a finishing polish and a black (or white) pad and perform a small amount of correction & gloss enhancement. All three processes can get you to a clean surface to reapply the Powerlock. You need to decide at which starting point you are at.
