Mike Phillips
Active member
- Dec 5, 2022
- 51,004
- 6
Removing #2000 Grit Sanding Marks with One Step by BLACKFIRE! LIVE!!!
BLACKFIRE One Step
A product that corrects, polishes and seals in one step
First - DON’T try this at home kids. Seriously - most people should NOT be machine sanding or even hand sanding with #2000 Grit sanding discs or wet/dry papers on FACTORY paint.
I did this to show just how much correction you can get out of this new one-step product.
I machine sanded my demo hood with #2000 Mirka Abralon Sanding disc and the removed 100% of the sanding marks using BLACKFIRE One Step, which is a one-step Cleaner-wax or more specifically a one-step cleaner/sealant sine it doesn’t use “wax” for protection but some form of synthetic sealant.
Since I’m typing live at the Ace Cafe Show - I’ll let the pictures do the talking.
First I machine wet sanded the paint using the Mirka Abralon #2000 grit sanding disc.
This is me lighting up the sanding marks, what looks like DULL PAINT using the SCANGRIP Sunmatch Swirl Finder Light.
Uniform Dull is what you're seeing here as machine sanding leaves behind a very uniform sanding mark pattern. Also on context - fairly deep sanding marks.
Now I've placed a tape line down the panel to separate where I'm going to buff from the rest of the panel and then again, I light her up!
Here you see three nickel sized drops or dollops of BLACKFIRE One Step Cleaner/Sealant on a RUPES coarse blue foam cutting pad on a RUPES Mark II BigFoot 21 Orbital Polisher (free spinning)
That's me holding the polisher while taking a pictures simply to document that "yes" it's me and "yes" I really did all this live at the car show. After taking the picture of course I held the polisher with both hands and worked the polisher over the paint.
That’s residue on the paint as I have NOT wiped the wax off yet...
NOW I've wiped the BLACKFIRE One Step off the paint and lit it up using the SCANGRIP Sunmatch Swirl Finder Light...
That my friends is showing you that 100% of the #2000 grit sanding marks have not only been completely removed but the product, the pad and the tool left a flawless finish.
I've moved the light over to the sanded side - if you look closely right along the tape line you can see the tale-tale signs of the sanding marks. That's because you cannot easily remove 100% of the sanding marks RIGHT NEXT TO THE TAPE as the tape creates a higher surface level than the actual paint surface and this higher surface level means you cannot push the pad and abrasives down onto the paint next to the tape line.
Over the BLACKFIRE One Step section....
Over the tape line....
Over sanded paint....
If you're looking for a GREAT one-step cleaner/sealant - get a 32 ounce bottle of BLACKFIRE One Step. It is amazing.
On Autogeek.com
BLACKFIRE One Step - 32 ounce bottle
BLACKFIRE One Step - 1 gallon jug
BLACKFIRE One Step
On Autogeek.com
