Hi
How can I remove 3M double sided mounting tape from my car (Foam type)? It was used to mount the plates. The car is Cqaurtzed and has protective film on the front end. The front plates are mounted on the protective film. The plates on the page are mounted on the body (that is Cquartz). I want to remove the plates and mount Euro-style ones. So plate damage isn't much of an issue. I don't want to damage the coating or the film.
Thank you
Thank you
