Hello all. I'm looking for advice on how to remove the adhesive left over from a clear bra covering half the hood and the front bumper. I (carefully) used a heavy duty McCulloch steamer to remove the clear bra, and the bumper portion came off easily leaving no adhesive residue behind. However, the hood portion was a real pain getting the plastic off and a thick layer of adhesive remained. My process for removing the adhesive is as follows: steam small area, rub MF towel with 3M specialty adhesive sprayed on the towel, and, if necessary, follow with a plastic razor blade. I've got about 3 hours into this and not much progress--at this rate it'll be days to finish. Any recommendations on how to safely speed this up?
Thanks in advance for your help!
