Hey all
I sanded and polished some hazed headlight lenses, but I can't get these fine swirls out.
My process was wet sanding with 800, 1200, then 2000 grit (in straight lines). I then used Meguiars M105 on an orange foam pad to remove the 2000 grit sanding marks - which are now all gone.
In their place are fine swirls (see image) that I'm guessing come from the M105. I've been completely unable to remove those swirls. I've tried using M205 on a white foam pad - I tried a generic pad as well as a Chemical Guys white hex pad.
I don't have a polisher, so I've been using 4" pads on a drill at between ~500 and 1500rpm (didn't seem to make a difference). Applying medium pressure to where the pad compresses a bit, and moving at around 1 inch per second. I'm not seeing any improvement after 4-5 passes, it's as if the 205 is doing nothing.
I also used M105 on a microfiber applicator by hand to strip the clear coating off the inside of the lenses too - since it was failing. I have similar swirls on the inside too.
The lens looks perfectly clear until I shine a flashlight on it, which reveals all the swirls. I'm worried that if I reassemble the headlights, I'm going to see lots of swirls in the sun or with the headlights on
Does anyone have any ideas for how to fix this or things to try? Am I right in assuming the swirls are from the M105? Why wouldn't the 205 be making any difference?
Thank you!
Here is an images of the lens under a flashlight, as well as two showing it under normal interior lighting.
Thank you!
