removing oil, sludge in the engine bay
mikbik
how do you guys clean the engine bay, I wanted to clean the sludge and oil and wanted to show natural look of a new car engine.
what product do you use on engine firewalls
I used to use Griot's Engine cleaner and a cheap paintbrush followed by a pressure wash.
I have recently tried Maguires Super Degreaser which is a bit more versatile.
Both work well.
<TED>
If is really 'bad,' there is always good ol' Gunk Engine Degreaser.
Bill
Bill
Gunk reminds me of the good old days!!!! That stuff always worked fantastic when I worked on old beaters. I still keep a couple cans around for the lawn equipment.
Umm..... what are you working on?
Brand new Kia?
watermark.php
1967 Dodge Monaco?
watermark.php
:dunno:
A couple cans of gunk gel, a toothbrush, a toilet bowl brush(i know but works great in areas), and a medium size hand brush and go to town. rinse with high pressure, but don't spray sensitive electricals with high pressure. I find simple green work good too but don't use it on plastic since it will leave a white residue in scratches.
Best thing I have found for removing actual oil is brake cleaner. Obviously you have to be very careful about overspray, breathing it, and if the surface you are spraying won't be harmed, but you literally spray it at the oil and it eats it away. I only have done this on my daily driver that had a small valve cover gasket leak and was very difficult to get in there to clean the area. A few spritz of brake cleaner and it was clean. This obviously would be for isolated areas with thick residue that can't be removed by another means.
Bill
That stuff works really well Bill and I even like its smell..... I started using it in the mid 70's to clean engines and apparently they've kept the formula pretty much the same....I think!
Bill
I still use it and I buy it in gallon tins. Then I use a garden sprayer to make it easier to reach the hard to reach areas.
They still have it from time to time in gallons at Walmart.
I saw a lot of different gunk engine cleaner/degreaser ranging from foam, original, hd gel? which one of this will solve a really 'bad' dirty engine bay.
after cleaning, what would be a good second stage to make it shine and maintain that new engine shine 'gray clean look'
Did I miss it? Did the OP ever tell us what he was working on? :dunno:
a toilet bowl brush (i know but works great in areas),
Actually I agree with you, a toilet bowl brush, ( clean one), works great for getting into hard to reach areas and then just toss it when you're done.
I don't recommend people to use my method to their own cars but here's what works for me to remove decades of sludge...
Here's a shot of the engine compartment painted with Hammerite...
No, he never said ...makes me wonder too.
ow sorry about that mike.
its an old car and wanted to have it restored and painted but never wanted to pain the engine w/ those high-temp paints, also planning on painting the suspension black but I need them clean before doing so.
@Mike.Phillips
is the hammerlite paint a better option compared to rust bullet? hammered look over glossy on the engine firewall
@Mike.Phillips
I would say most people would not care for the "hammered" look as compared to normal high gloss finish.
The benefit to the Rustoleum Hammered paints is they fill and cover like a sun-of-gun and touch-ups are very easy to blend.
I've never used the Rust Bullet brand you mention but the Rustoleum Hammered line of paints are also available in non-hammered or high gloss finish.
