Removing old touch up paint.
CanuckCleaner
Hey Mike
I just bought a car and the PO had put touch up paint on chips in globs which I'm not happy with. Is there any process to removing the touch up paint and filling the chip properly?
Canuck
It would be easier and more conforming to wet sand the "glob" down to a flush level with the surrounding paint.
As long as the chips are completely filled then the sanding will look pretty good. Sounds scary, but it really isn't.
I've found that the Langka solution works fairly well at removal of old touch up paint, without running the risk of using sandpapers and possibly cutting through clear-color coat.
You can work and rub for a long time without harm, and I have smoothed poor touch up I did on my vehicles that on one, had been applied at least 12 years prior.
Yes, you'll have to rub more, but if you only concentrate on the blob, no harm should come to the surrounding factory applied finish.
Dependent upon how well the touch up was done, you may not need go any further than the Langka Solution, that the Blob will be leveled to your satisfaction.
If not, then I would suggest a follow-up with a paint touch up system such as Dr. Colorchip, as I think this system works a lot easier-better than Langka.
Dr C Chip paint formulations has advantages of ultra quick drying, which one can level excess within a few minute's time, something factory type touch up paint doesn't do. It also stays put when doing touch up on vertical panels without a tendency to run-sag.
The Langka product is available right here, and Dr. C Chip can also be ordered here, and is then dropped shipped direct from the company.
Hope this helps you.
Thanks for the responses. I really don't want to break out the paper so I'll probably start with the langka and see what happens.
