spagett
- Mar 20, 2015
- 18
I applied OGC last spring and strongly believe I applied too little on several sections. This spring I will redo the entire process but want to know if I need to concentrate on removing the remaining OGC FIRST (polishing) or go about the full detail in the normal order (wash - decontaminate - polish, etc.). Regardless, will the panels that still have OGC on them require any more polishing than normal, ie polish once to remove coating, then again to remove defects? Or would you suggest just approaching the whole process as one normally would?
Thanks guys!
Thanks guys!
