Removing overspray from fresh paint job
Dr76
Hello, recently had my car painted by a "get-what-you-pay-for" nationwide chain, and although it was laid on nicely (especially for the price), there are, of course, areas of overspray. Was wondering what product(s) would be best to remove the overspray from rubber window moldings and from various metal trim pieces. Do I dare use a razor blade to try to scrape the rubber molding areas? The metal trim pieces are all a flat/matte black finish. Is there a product that would remove the "fresh" overspray, but not attack the original matte black paint beneath it?
The car is just a 12-year-old daily driver, so not looking for perfection by any means, just wanted to touch-up the obvious flaws. Was painted two months ago, so any "curing" should be compete (if that matters?) Base coat / clear coat.
The overspray is from rushed tape-jobs that just didn't get close enough.
Thanks for suggestions / replies!
The most common place to get overspray paint on your car is while it's at a body shop. Could happen inside the paint booth or outside the paint booth because overspray paint drifts around in the air.
There's no "specific product" that I know of made specifically for your application but I've had good luck using this product.
I've had good luck with Xenit from Stoner's.
The "trick" is you don't just wipe it on and off... you have to dampen a microfiber towel with this citrus oil and hold it against the trim so the oils has some time to dwell, penetrate, soften and loosen the offending overspray paint and then wipe the trim.
Depending upon how much trim you have to clean this could be time consuming but very safe.
Stoner XENIT Natural Citrus Mold Cleaner
Stoner XENIT Natural Citrus Mold Cleaner removes resins, carbon deposits, silicones, and contaminants from molds. You’ll never again be frustrated trying to remove tough gunk and grime in your home, office, garage or car. Natural citrus XENIT by Stoner removes tacky, grimy dirt so well, in most cases you can simply “wipe it away.”
XENIT is a natural precision mold cleaner used as a degreaser in the plastics and rubber molding industries. It contains Citrus 66, a highly refine extract of citrus fruit. This powerful ingredient removes greasy soil and stains that can't be removed by soap and water.
Use XENIT to quickly permanent marker, crayon and lipstick “accidents” in the car and around the home. It removes release agents, resins, carbon deposits, and other contaminants left in mold cavities.
XENIT contains more than five, different, high performance cleaners. Unlike most water-based citrus cleaners that are designed to lift and carry dirt, XENIT is formulated to break down the complex molecules found in sticky materials.
This MicroActive cleaning action gives XENIT unequaled abilities to loosen and dissolve difficult grime like tar, grease, gum and adhesives. It even removes dried latex paint if accidentally dripped on carpet, flooring, or furniture. XENIT removes shoe scuffs and heel marks from from vinyl panels and greasy dirt from fabrics and upholstery.
Save yourself hours of agony trying to remove sticky stuff with standard cleaners. Avoid wasted time spent laboring with inferior water-based products. XENIT is formulated to evaporate and dry completely, leaving behind no sticky residues or streaky soaps.
Try the Xenit soaked in a terrycloth cotton wash cloth. Hold the dampened wash cloth against an area you want to clean and allow the citrus oils to penetrate and then rub rub rub.
Since this was your first post...
Welcome to AutogeekOnline! :welcome:
