So I have a set of alloy wheels that were plasti dipped at some point by a previous owner. The visible outside (painted) surfaces are completely free of plasti dip and it has been removed well, with no damage to the clear coat etc.
BUT, on the insides (non-painted rough areas), as in the inrer surface of the 'barrel', inside lug nut holes and on the barrels (the tire mounting surfaces), there's still some light/thin residue, at some points thicker 'blobs'. I have tried using Sonax wheel cleaner and and soap water and pretty heavy scrubbing with a household scrubbing pad/sponge and some of it came off, but not completely.
What product(s) and method(s) can I use to remove this left over residue of plasti-dip?
I don't have any special tools like pressure washers or anything.
I know that the surfaces that still have plasti-dip residue are normally not visible, and shouldn't really affect anything, but I want the wheels as clean as can be before getting them installing...
(The wheels are simple 5-spoke star style, so I guess if someone did peak, one would be able to see the stuff on the inner 'barrel'...)
Any help/advise would be greatly appreciated.
