Do U guys thing menzerna 3500 will do it? Fresh coat... How about Griots correction creme?
Applied last month but now I want to buff it off a couple panels. Pa came out with a new glasscoat by the way
POLISHANGEL® GLASSCOAT™| COSMIC SPRITZ SPRAY is the latest developed spray coating with PRIMER adaption which allows us know to get a minimum protection up 12-14 months.
COSMIC SPRITZ SPRAYCOAT has a very high concentration Silica and Titanium Dioxide. Silica produces an extremely hard durable surface that protects against corrosion. Titanium dioxide provides extreme shine and color transparency.
COSMIC SPRITZ requires only a minimal amount of product to be effective. COSMIC SPRITZ leaves no residue on the plastic parts. Can be used as a drying aid.
With COSMIC SPRITZ SPRAYCOAT COLOUR there are new star born which excell, in a never been so easy way, the full spectrum of your car colour.
POLISHANGEL® specialise in colour-matched and perfectly interlocking handmade automotive finishing systems. This exclusive and unique system is unmatched in quality and sustainability. Each colour pigment generated is called a special colour spectrum or light spectrum. Millions of special micro pigments produce an extremely concentrated colour density to create a firework of spectral colour.
Type your colour into the Colour box.
:: For Colour Code Matched type the colour code followed by the colour name.
**example for Ford's Tangerine Scream:
"M7280A Tangerine Scream"
:: For a generic single-colour, simply type the generic color into the box.
**example: "Black"
Durability : 12-14 Months
*:NOTE:* 2-Part System - Use INVINCIBLE | PRIMER or PRIMER SPRITZ before COSMIC SPRITZ SPRAYCOAT form the full hardness.
POLISHANGEL® GLASSCOAT™| COSMIC SPRITZ SPRAY COLOUR is the latest developed spray coating with PRIMER adaption, which allows us know to get a minimum protection up 12-14 months.
Yeah its supposed to replace cosmicv2 and v1. If u noticed they are off the page now.I recently removed a (I think) much heartier coating with B & S Uro Fiber pad and GG Correcting Cream. I don't think Cosmic is all that tough.
I see they released a 'new' Cosmic but am kinda confused.
Is this essentially a new Cosmic Spritz version, beefed up with the addition of the Primer step or perhaps the current Cosmic Spritz re-packaged/re-imagined as a spray coating with the addition of the primer step?
Apparently a new 'colour matched' Cosmic is available, albeit at $169 for 200ml...ouch. When I talked to the PA Rep from Germany at an Open House a few weeks ago, he mentioned colour-matched Cosmic Spritz was forthcoming but it looks like they've renamed or reclassified the Cosmic Spritz into a dedicated coating?
Color matching reminds me of the old colored Turtle Waxes. I can see color matching on single stage paint but on clear coat? Optically transparent would be the best “color”.
