removing polish?
shadybreal
Would anyone mind composing a list of polishes in two categories? One w/ polishes that are easy to remove and one w/ polishes that are difficult to remove. I've been having a tough time lately getting all the residue off the vehicle. Seems like I may even add some light marring trying to get it all off. Any tips you may have would be nice as well. Thanks!
In most cases if its hard to remove you probably havent worked it long enough to flash.
For hand, orbital or rotary?
The SSRs and XMT line are the easiest polishes I've used via PC or UDM. Menzerna and Optimum with a rotary are fairly easy to remove, when worked in properly. Powergloss gets a little finiky when working with, but a little extra elbow grease or micromarring isn't bad since you'll need to use a final polish afterhand...
