Removing Shoe Polish from Carpets?
allenk4
In time out
BEFORE
AFTER
Note: It is a beam of light causing the lighter area above the Mercedes Logo
Overall, I am pleased with how these floor mats turned out
The Owner was surprised how clean I was able to get them
I was, however, unable to remove what I think is Shoe Polish. I believe it is shoe polish based on the color and where the stains are located on the carpet. I looks like it rubbed off of the back of the Driver's Shoes
Any suggestions on what could have been done to get that last little bit out?
My process was as follows:
- Brush with Blue Cyclo Brush on a PC
I think the stiffer white version is probably better for carpets
- Vacuum
- Spray with Folex
- Dwell
- Agitate with DA
- Rub with white cotton towel
- Hit stubborn spots with Optimum Power Clean (APC)
- Agitate with DA and stiffer hand brush
- Rub with cotton towel
- Hit it with Folex again to neutralize the alkalinity of the APC
- Blasted the mat with a hose (careful not to get the foam backing wet)
I had applied quite a bit of liquid cleaners at this point
- Wet vacuum to extract the remaining liquid
- One more time with white cotton towel to remove remaining dampness
By the time I got to the last step with the cotton towel, there was no color/dirt coming off
1st three mats took 20 minutes. 40 minutes on the Driver's side mat....way too long
Quick Tip:
Don't lay a $200 floor mat directly on the ground, put something underneath it
Protects the back of the mat and looks more Professional too
You're not going to get this out,that stain is cause by the dye of the shoes,I've try hundreds of times to get those type of stains out nothing works
An alkaline doesn't neutralize an alkaline...(i highly doubt folex is alkaline)
A solvent will dissolve shoe polish. Ideally you want to use one made for carpet and upholstery but goo gone or goof off will work okay. Just rinse like crazy with water.
Matt
Professional carpet cleaner
With the right products and education it is possible to remove.
I'd say I have a 20-50% success rate.
Many times using the wrong products will set stains.
Matt
I am told that Folex has a pH of around 7
Will try Goof Off next time
Thanks
lol
From what I am learning you want to try a non-alkaline cleaner first, because alkaline cleaners can set Organic Stains on some instances
I believe Meguiar's is now suggesting that their new D106 Fiber Rinse & Tannin Stain Remover be used 1st and then APC or other Alkaline product that works on grease & oil. Not sure if a 2nd application of the Giber Rinse is required at that point
Matt
Matt,
Does AGO sell anything that fits the description above?
If not, can you suggest something
Thanks,
Kyle
Great work.!! May have to dye the carpet to back to normal... Not all comes out... Nice post , good work, do not beat yourselve up!!
Got sucked into the YouTube Vortex for two hours watching Professional Carpet Cleaning Videos
The guys who are doing office and home carpets look like they are way ahead of us Detailers when it comes to specialized products for things like gum, nail polish, red stains and shoe polish
Looks like I will have to make a trip to my local Pro's Choice retailer for some goodies
You are on the right track. Pro's choice is the way to go.
lol
Not necessarily.
I honestly don't know why you would use an acid 1st. This makes absolutely no sense. Maybe meguairs need to take an IICRC class on carpet and upholstery if they are truly recommending a fiber rinse prior to pretreatment for general soiling and stains.
Most stains are on the acidic side so you use alkaline. This neutralizes the stain and allows it to be lifted. But there is a lot more to stain removal than that.
Do you have any comment on the Meg's Detailer line D106/D116 carpet cleaning system released last year that Allen mentioned?
PS Allen there was a good Detail Fest presentation on the system here: https://www.youtube.com/watch?v=HweQSpYdhRs
It's good to see they are offering stuff for you detailers. But if you really wanna become an expert take a class or go to a local supplier. Jon don, interlink. But be careful. Some stuff is highly concentrated and is possible to take color out of carpet and upholstery.
Fiber rinse is great to see. Neutralizes ph. Reducing residues that contribute to rapid resoiling. May help the fabric to dry soft. May speed drying.
It probably wouldn't be very effective against wine tea and coffee. It may work and may not work in some cases. Also it will take several hours before it starts to lighten up so don't expect instant results unless it easily rinses out which sometimes tannin stains do. I don't think I have ever seen a fiber rinse with a tannin stain remover combined. But I think they are trying to keep it simple.
Additionally tannin stain removers are the most effective at removing wine tea coffee etc. Oxidizers work so much better but you need to know what you are doing.
Protein stain remover is good too. But Oxidizers work better in most cases.
What is an Oxidizers.....go take a class.
Edit....tannin stain removers are NOT the most effective at removing wine coffee tea....Oxidizers are typically much more effective.
If its shoe polish then you need a solvent. Naptha, mineral spirits, brake clean , will get shoe polish out . Naptha is very flamable so be careful.
