Removing Smoke Stains
2SLICK4U
Removing a smoke stains from the visor and seats and some on the celing , not much but still i can't stand the smell , my question is which product i should use for the smoke stain and for upholstery there is so many choices i don't my spending little extra for better product. This is what i have DP Carpet Extractor Pre-Treatment and DP Carpet & Upholstery Cleaner ,should i get some other stuff or is that enough for my cleaning. I was thinking about buying a Bissel Little Green do you think that would clean better ? maybe some other suggestins on what should i do my upholstery is gray,
I cleaned a whole car with Bissel Little Green and worked very nicely. I would suggest Clear Air Genie Fogging Air Freshener, as for the cleaner I used something found in local retail stores. I will try DP products next time (have not used the Dakota product yet).
Just remember to purchase the Little Green from a local store and I hate to say it but if you dont like it return it, cause it has its limits. This machine is not bad for small projects, even weekly cleaning.
For smell, Duragloss Odor Absorber worked rather well for me. I did find even in smokers cars that Einszett A/C Cleaner (Klimate Kleaner) worked well too, its as if the smell somehow locked in there and a/c spread it around.
Scott is right make sure you treat A/C to get a complete cleaning! Otherwise everytime you turn on the A/C its going to stink it back up!
Thank you for answers but how about the smoke stains would i be able to remove them with my DP products or i should buy something different for smoke stains ,what do you guys recomend, once again thank you
Not sure about DP products, but a good APC will take care of the stains.
Which brand APC should i get there is so many of them can some one recomend a good one
Which one i should get out of these three Chemical Guys, DP, Meg's APC+ or Poorboy's ?
I'd probably shop on price per use. Meg''s APC+ can be diluted 10:1.
I just recived my Meguiars APC+ AND will do 2 cars with little green
