Hello, i would like to remove these tiny spider web from my pc plexi panel and am thinking of buying meguiars plastx.Will the plastx able to remove these?
Never had experience with drill or wet sand and i am thinking of applying by hand with this:If they are just spiderwebs why don't you just use a damp sponge to remove them?
oke:
Okay, bad joke![]()
PlastX by itself (applying by hand) will greatly reduce your spiderwebs. If you want even better results try using foam pads and a DA or Drill with your PlastX. You could also wet sand and then polish
What is that, a screen door?
Hello
PC as is Personal Computer?
I have never used plastx.
But wet sanding might be to extreme. If your going to use a drill I'd imagine this would work
More Shine In Less Time With Meguiar's® Dual Action Power System - YouTube
Good luck and just trying to help.
thisNot sure which foam applicator you mean. However, I am pretty sure the pads shown in the video ^ would be able to be done by hand.
At the shop we sometimes to buff out small areas by hand and a MF towel as well. About 1"x1" section (give or take)
about the even coat i find a topic here:I've never used the 3rd picture, the even coat. The other 2 seem more for application.
These seem like they would be more designated for the job.
EZ Grip Hydro-Tech Hand Applicators Trio - Your Choice!
Or this and some 3" pads?
Meguiars Unigrit 3 Inch Professional Hand Pad
Check it out at 2:13:30 (give or take) or you can do like me and just watch the whole thing Im the MAN:buffing:
Mike starts buffing by hand. A microfiber towel should be fine. (sorry not familiar with what is available to you out there, either way, :welcome:
Part 1 - How to Wetsand, Cut and Buff a 1965 Mustang Fastback - YouTube
oke:
sorry for asking too muchNP and they were most likely Microfiber
I don't mind
Well hopefully you do succeed and if not report back. I'm sure others will be able to further help.
