addysdaddy
- Jun 13, 2012
- 980
So I REALLY hate these things but have been afraid to attempt removal for fear of damaging the material-not positive if mine are vinyl or leather but I'm assuming vinyl. In one of the other forums there is an on-going thread about exactly that but I wanted to run these methods by our members to get some feedback prior to giving it a try. Below are the two approaches that seem to get the desired results easily and safely. When I read one of the guys used acetone for removal I cringed but....if it worked it works. What do you think?
Suggested removal techniques:
Method #1
Even better and easier than removing the visors is this little trick I tried today that worked to perfection.
Simply pull and unsnap the visor from its stowed position and swing it around as if you were trying to block the sun from the side window. Now rotate the visor so that the sticker side is facing up. The visor is now in a perfectly horizontal position.
Now take a kitchen paper towel and fold it such that it will just cover the area of the sticker. Now soak the the paper towel with Denatured Alcohol (that's what I used) and simply set the alcohol soaked paper towel over the sticker. Next, take a thin plastic bag - the kind you get at the produce section - and slip it over the entire visor and twist and tape the open end shut so that you seal everything inside, preventing the alcohol from evaporating.
Take a nap (that's what I did, truth) and after an hour or so remove the plastic wrap and simply peel the now wrinkled sticker off. Voila! It comes off intact! Amazing!
There is, however, some residue remaining that will need to be cleaned up. But I'll wait until tomorrow to do this, just so the vinyl can recover from the sudden shock of fumigation. Seriously, the vinyl needs to rest after this shock treatment.
Method #2
I put a bit of acetone on a cheap microfiber cloth and rubbed it against the sticker. Less than 10 minutes I had both of them off. It worked perfectly, no marks, scratches, fading, nada.
Method #1
Method #2
