Removing Sticky Residue From Glossy Black Plastic Spoiler.
Darvetis
Member
Hobbyist detailer here. Purchased a new Mazda, had the pleasure of peeling off the white sheets of car transport film myself On the glossy black plastic spoiler, there is a faint thin line of adhesive residue where the edge of the transport sheet lay. What product (household or otherwise) can I use to remove that adhesive, without messing up the black trim?
Dawn dishwashing liquid, Xenit Citrus cleaner, WD40, isopropyl alcohol? Any suggestions appreciated.
My go-to is 3M Adhesive Cleaner. A pint will last you at least 10 years. Get the liquid, not the spray.
As always, do a test spot first.
Ha, I use the Auto Adhesive Remover, which only seems to come in the spray can, P/N 03618. Although they still sell it at Amazon (which is where I got it), I don't see it at the 3M site.
Yes, it worked, I was trying to get across that I wasn't familiar with THAT 3M adhesive remover, the General Purpose which is available in the squeeze can or aerosol, only the Auto one. They now have a citrus-based "low-VOC" product, also. The one you linked is also available at Amazon.
