Vehicle in question is a 2014 Ford F150. Since purchasing it new I have had it sprayed with Krown rust protection annually. I know that the Krown product "creeps" over time and therefore expected some product to be present around door jambs, tail-lights, etc., but what I have noticed recently is what seems like a 'film' on 75%+ of the body surface.
When spraying the vehicle with straight water or my foam cannon you can see the obvious areas around the tail-lights, bottoms of doors where the water gets repelled instantly. When I'm drying the remaining panels with my PFM towel it looks like there is a residue being left behind after a wipe (some are worse than others) I should also point out that about a month after I have the truck sprayed I clean all of the product from the door jambs, tailgate and hood as I prefer these areas to be clean and not covered in black residue.
The truck will require correction later this spring, so I will need to get down to the bare paint surface. In the interim, I would like to get the truck's paint down to a clean surface but am unsure what product(s) to use. I'm thinking of a highly diluted degreaser of some variety, but not sure how safe that is on paint. I know the commercial says "a drop of Dawn and grease is gone" - would that be strong enough? Appreciate any assistance/suggestions.
