Hi,
I picked up a (black) car a few years back and it had a coating on it. It has since developed some light swirls that I wish to remove. However, I do not intend to re-coat after polishing (One reason for not re-coating is that I don't know which coating was applied). Instead, I will apply a carnauba wax.
I worry that I may end up removing the coating in some spots and not removing it in others, and any wax I apply will adhere in a non-uniform way (by non-uniform I mean adhere differently where the coating remains and where it doesn't).
- In this case I am guessing that I should simply remove the entire coating?
- I don't have an EPTG, so would the best way to know when it is removed to check for water beading (after cleaning polished surface with IPA)
