First, since this is your
first post...
Welcome to AutogeekOnline! :welcome:
but this time I just sprayed it directly onto the steering wheel.
In doing this, I over-sprayed twice onto my clear plastic cover over the speedometer/tach ('13 Civic).
Yep... it's always best to apply interior cleaners and dressings directly onto the applicator pad or a microfiber towel and then apply to the surface versus spraying directly onto the surface as you've experienced you get overspray all over the place.
From your description, it sounds like something in the CG dressing has stained the plastic surface or possibly any factory coating on the plastic surface.
Hate to be the bearer of bad news but most stories like this don't end well. Two problems,
1. The plastic surface is delicate and easily harmed.
2. Due to the location it's hard to work on.
when I went to clean it off, it appears like it has become a ton of permanent little spots all over the panel.
I've tried CG Superclean, Goof-off, window cleaner and dawn and nothing seems to budge it.
It won't even scrape off.
More bad signs.
If the dots of product won't scrape off, that means whatever was in the dressing has likely had a chemical reaction with the surface of the plastic and dissolved and etched ONTO it. Now it is one with the plastic.
Since window cleaner and a dishwashing soap, (Dawn), had no effect, that's more bad news as the first thing I would have tried is a warm solution of soap water dabbed on with a clean, microfiber towel.
At this point I think you're down to one option to try and that is a plastic polish.
PlastX by Meguiar's is a true plastic
polish with the ability to abrade plastic without leaving behind it's own scratch. You could try applying this with a clean soft foam applicator pad.
The below are plastic surface cleaners that you would basically wipe on and then wipe off and they work good to clean NON BONDED dirt of the surface but if these dot stains are resisting even scraping then these probably won't work.
Detailer's Plex-All
RaggTopp makes a
plastic cleaner it might work.
303 Aerospace Protectant can be used on clear plastics to clean them.
In case nothing works I've machine polished gages before using foam pads on rotary buffers the deal though is if you can't remove the gage lens then you have to be able to get to it through the steering wheel openings, etc.
Not sure I helped?
:dunno:
