...with that said, if water on fresh wax doesn't hurt the wax, then I think it would be fairly safe to say that quality QD wouldn't hurt it either...
I never know how in-depth you guys want to get but here's something to consider...
There's a HUGE difference between running water over the finish and wiping paint with a liquid.
Running water doesn't include any type of extra material coming into contact with the paint and physically rubbing against it.
Wiping paint with a quick detailer or spray detailer usually includes spreading the product out and then removing it with some type of application material, in most cases a microfiber polishing cloth.
Anytime you "rub" a freshly waxed surface or a freshly paint sealanted surface, (is sealanted a word?), you disrupt the protection ingredients before they have fully set-up, in simple terms, you're moving them around from where they were deposited and removing them off the surface and onto the microfiber.
I won't pass judgment as to whether wiping a freshly waxed or paint sealanted surface is good or bad, that' up to you to decided, but IF the goal is to leave behind the greatest amount of protection possible then touching the paint less after initial wipe-off would be from a common sense point of view, going to help you attain that goal better than wiping the finish with anything.
In my list of articles here,
Articles by Mike Phillips there's an article called
The Final Wipe – Tips for creating a streak-free, show car finish
And this discusses how microfiber technology is very good, if not superior to other types of cloth, for removing trace residues off painted surfaces.
If this is true, that is if microfibers, the actual microscopic fibers themselves are superior at REMOVING trace elements and even larger residues than trace residues off the surface then put the discussion into extremes..
- Will wiping more and more leave more wax on the surface?
- Will wiping more and more leave less wax on the surface?
Take it a step further, if you spray on a liquid that in some cases offers some lubrication and cleaning ability, and now you wipe this over the surface,
- Is it adding more wax or paint sealant to the paint?
- Is it removing some wax or paint sealant from off the paint?
Now if you're just into the beauty aspect of waxing your car's paint or applying a paint sealant to your car's paint then the goal is beauty, not leaving behind the maximum potential of protection ingredients and none of the above deeper thoughts on this topic really matter. This would be more targeted at Garage Queens and other toys, not daily drivers where in most cases people want maximum protection to preserve the paint from deterioration as it is exposed to the outdoor elements and wear-and-tear more so than a garage queen.
