Removing wetsand scratches what am I doing wrong
maesitos
Hello!
I'm a bit frustated at this point and I'd need some help. I read many articles and watched many videos about this topic that's why I decided to create this thread.
My BMW Z3 was just repainted with two clear coats but the surface had a lot of orange peel. I decided to wet-sand a panel using my Kestrel DAS-6 and 3M discs: fist 1500grit (without foam interface) then 3000grit (with foam interface) followed by 6000 grit.
My problem: I cannot remove the sand marks.
I tried using the DAS-6, Menzerna FG400 and a yellow pad (most aggressive) with no luck. Then I tried with my rotary at 1500rpm, Menzerna FG400 with the yellow pad but still I cannot remove the marks completely.
This clear-coat is obviously hard but I can't believe I can't get rid of the marks. Am I missing any step? Should I try wool? Will the wool really make the difference? Should I make smaller steps with the sanding —something like 1500, 2000, 2500, 3000?
Any help will be appreciated.
FG400 will easily remove 3000 grit sanding marks IF you actually have 3000 grit sanding marks
I suspect that you may have come up short of removing the 1500 sanding marks with the 3000 grit step
This can be exacerbated if you are inducing Tracers in either sanding step
Do you have any microfiber pads for the da, or wool for the rotary?
Hello:
I just came back from insisting a little bit more with the 3000 grit un a test spot but still I'm no t able to remove the scratches. The sanding haze is gone and the surface is shiny but from the right angle I can see it's full of sanding marks. There are no tracers.
I took some pics for you to see the scratches. From the distance it looks flawless.
I only have a wool pad that came with the rotary machine but I don't want to try since I don't know if it's a bad quality wool or very aggressive. I do have a cutting microfibre pad for the DA but it does not remove the starches either.
What can I do?
Spend more time compounding. If the paint is very hard it can take quite a while to polish out sanding marks with a DA.
Hello Guys:
Since the detailing shop is closed today and I don't have wool pads I grabbed a denim pad, used it with the rotary and believe it or not, this thing removes 3000grit scratches in a few pases (4-6 passes in my paint/diamond). Denim pads are meant to remove orange peel but apparently they work great to remove sanding marks too.
I guess the wool pad is easier to handle than this denim but the denim is not that bad.
After the denim pad I have to polish with the DA, yellow pad (the most aggressive) and Menzerna FG400 in order to remove the swirls. Definitely my clear coat is a diamond. Using a medium polish (V36 in my case) and a polishing pad (orange), doesn't remove the swirls at all.
I'd like to say that I'm a complete novice in this area and reading info here and there I was super scared of using a rotary but I think people like to tell dragon stories. Unless your paint is butter, using a rotary is easy and I'd recommend to any novice to try it (taking into consideration the correct usage) after a few hours of practicing a little with the DA and if they don't achieve the desired results only using the DA (least aggressive first, so DA fist to see what happens). The worst thing that can happen is to visit the paint booth...
I'm super happy now! Im the MAN
Hello Guys:
Rotary might be easy to do what you was doing. But concave and sharp raised edges thats where the skill and knowledge of a pro and novice with that machines come into play.
A rotary on a flat panel is as easy as a da to work.
The da you can mess up and it will forgive your mistake.
The rotary you can be focused on one part and didn't notice at the other end you hit a body line and burned thru.
Just because you had success on what was fairly easy doesnt mean you shouldn't respect that machine and what it can do.
You also have to remember if your clear was that hard using a rotary was basically like using a da.
Using a rotary on normal or soft clears you take paint off at a more excessive rate then the da.
As because the clear was so hard on your paint using the rotary was actually safer.
In example: your clearcoat was hard and a da simply wouldnt cut it because a da dissipates the heat.
So you needed direct drive more heat to correct the sand marks.
The same heat you had to generate to correct that clear you might burn through on a honda paint.
I know that my g21 boss can generate some serious heat with a mf pad. I dont know what da machine you was using just be careful. With the rotary on normal clears.
The rotary on that hard of a clear is more safe then normal clears.
Am i saying its impossible or you shouldn't no not at all.
All im saying is don't get so comfortable just because it was fairly easy on that car.
Thats how you get into trouble
Who is NextLevelDetail?
Why can't I understand what you are trying to tell me?
Your advice is suspect...IMO
Your grammar reinforces this opinion
OP
There is NO way you need Denim to remove 3000 grit sanding marks
Something is way Wrong
Take a close-up photo
Put your finger tip in the photo to give your camera something to focus on
What does that mean "who am i"
That makes no sense its a forum.
I was not trying to tell you anything, i was talking with the op.
As far as my typing goes, i am on a new phone and new keyboard.
That im getting adjusted too.
As well as my daughter taking the phone from me while i was posting.
Was not talking too you. So you can take a long walk on a short pier.....IMO
OP said it required Denim on a Rotary to remove 3000 grit sanding marks
Does that sound insane to you?
Have you used Denim
I asked, what are you trying to tell me because your post didn't make sense to me.
As far as having a new phone, keyboard or other distractions...if you click "Advanced" you can preview your thought before parting to the Forum
Have you used Denim
Once again, I was not telling "you" anything, i was talking to the op. I do not know why you took my message so personal.
"Who are you" "what do you mean"
"Who is nextleveldetail" (although my name is nextleveldtail)
What are you a cop with all those questions ? Do you want my i.d ?
All paints are different, he said that is what got them out. And the photos look great to me.
I got out 3000 grit marks with menzerna 3 in 1.
However every paint is different no need to question the guy problem solved.
If you dont like my posts dont have to read them, once again i was not talking to you. Keep your cop questions to your self this is a discussion forum.
To the OP....
While you can remove sanding marks with any tool that will remove paint and also your hand, (I have two articles on this forum showing me remove sanding marks by hand), the fastest and most effective way to remove sanding marks is with a wool pad on a rotary buffer.
:dblthumb2:
