Removing Wolgang Sealant off of plastic and rubber trim
JasonGTI
Hi, I've applied the Wolfgang sealant to my car a couple of times and I love the protection and look. However, I accidentally applied some of it on my plastic and rubber trim. Now there is a white residue on the trim. I tried peanut oil but, it was only a temporary fix. Do you guys have any suggestions on how to remove it? I plan on applying the Wolfgang trim Sealant after I'm able to remove the residue. Thanks!
i use the mr clean magic eraser...works like a charm..just soak a small piece with clay lube and your good to go my friend...
Do you think that would work for any product that stains trims? Like New Finish ?
I use Zep citrus degreaser at full strength to clean residue off trim. I've removed year old M105/205 residue with no problems. Any automotive APC or degreaser should work, just don't get it on the paint. Saturate a microfiber with it and scrub.
Sent from my DROID RAZR using Tapatalk 2
I know this is an old thread
Any tips for getting this sealant off of textured plastic trim? I can't quite get the Degreaser in the texture.
Sent from my Pixel 2 XL using Tapatalk
Mineral oil on a cheap microfiber rag. No need for expensive removers.
Sent from my Galaxy Note 8 using Tapatalk
The magic eraser does work. Just make sure that you don't touch the paint with it. You might want to tape off the painted sections. I also use some APC sprayed on an old toothbrush.
View attachment 64684 honesty nothing cheaper easier or more efficient. No damage, just wipe with a damp cloth after. You can get ito small tight areas. No harsh chemicals to breathe in.
