Currently, I see 3 polisher roles as it relates to my work. The big guys (Boss G15 or MT300), a Mini (gg3 in my case currently) and a micro (nano, which I don't have yet).
It's really the off season for me and as such I'm looking at where to invest my money to further my business when the good weather comes around. I'm completely satisfied with my Boss G15 and see no reason to bother with a 21mm machine. But an area I think I can take advantage of upgrading is in the mini role.
Currently I have a GG3 and while I can sometimes get decent correction out of it on high speeds, it feels like it lacks. I typically use it with thinpros (orange and white mainly) and it's been great for my production jobs w/ M37 360, but if I were to get into more serious correction work, I doubt it would really be enough and definitely would leave a noticeable gap between the results it provides and the results that the G15 can provide, even with the 2" conversion kit I purchased for it.
So I've been thinking of upgrading it. In the running for that upgrade are the Rupes LHR75e, the Flex XFE-7-12-80 and the Zentool 12e all of which are DA. However, I've also been toeing the line toward rotary lately, and options such as the PE8 have caught my eye. The ability to use 1", 2", and 3" pads as well as extensions for harder to reach spots is really nice.
It seems to me that although you'd need to be a lot more careful with RPMs with the movement being spread over such a small area, the pe8 as a rotary should have more correcting power. But for those who've used both, does it really?
I'm basically just trying to understand where I should spend my money before I plunk down $300+ on a Rupes or Flex mini and only end up disappointed (read: the results aren't significantly better than the GG3 for the money), when a mini rotary is less money and at least according to physics, should be able to correct better. If it helps any, I'd been leaning toward the Rupes 75 or Zentool 12e until I started considering the pe8.
