I have PPF and fresh but fully cured Adam's Advanced Graphene coating. After a drive today, I noticed that there were about a dozen spots in front of the car. They do not look like tar. They could be bird dropping but I am not sure. Based on their roundish shape, they were in liquid form when they contacted the car.
I used some waterless detail spray and was able to remove them with a bit of rubbing, or so I thought. Even though they were no longer visible to my eyes under the garage shop lights, they are still there.
As you might know, Adam's coatings have a UV tracer. Under UV, all those spots light up brighter than the graphene ceramic coating, as if the spots were never removed. I washed the area with soap, it made no difference. Neither did 50% IPA. Whatever it is, I don't want it to etch into the coating or PPF.
What can I use to try to remove these spots without harming the ceramic coating or PPF? I want to use only what is necessary to remove the spots, in escalating aggressiveness. It's hard to find the right solvent not knowing what the spots are. The only clue is that they fluoresce under UV. Windex? Simple Green? I don't want to use Goof Off or Goo Gone in fear that they will damage the coating or PPF.
I'd appreciate some advice.
Thanks.
Thanks.
