Is there anything to be done to improve the appearance of sun faded door panels? My vehicle has some fading damage right at the top of the panels where the window meets the panel.
That is most likely sun damage though if its vinyl(plastic type) material try cleaning the surface with a interior or all purpose clean and a few coats of trim dressing to see if it will help
I think I know what you mean. Do like jamesboyy suggested ans try Solution Finish to bring back the color. Assuming it is black. (Not sure if it works with other colors, so can't comment on that)
Or you could try and plasti dip it too.
A lot of the other dressings don't last very long.
The only thing that I can think of is some kind of dressing to help the appearance; UV damage is UV damage unfortunately. It degrades all unprotected surfaces in time.
