Nick McKees37
McKee's 37 Product Support
- Jan 6, 2011
- 7,265
In car care and detailing, sometimes the most tedious and laborious jobs can be the most rewarding. Case in point: metal polishing.
Metal polishing is hard work, especially if you're used to spending a Sunday afternoon wiping off a thinly-applied coat of Pinnacle Souveran - something that takes no effort, literally. So when Max approached me to give his Albury Brother's boat trailer the shine it deserved, Marine 31 Finish Cut Metal Restoring Polish was the obvious choice for restoring the brilliance to the diamond plate fenders. Here's why: it's exceptionally easy to use and, most importantly, it works.
Marine 31 Finish Cut Metal Restoring Polish is a medium-cut polish designed to restore the brilliance and luster to uncoated aluminum and metal surfaces on your boat. Marine 31 Finish Cut Metal Restoring Polish creates a mirror-like finish that can be seen from a distance. If your boat’s brightwork is dull and oxidized, give it the attention it deserves with Marine 31 Finish Cut Metal Restoring Polish!
Diamond plate fenders on Max's boat trailer
Doesn't look too bad 'eh? Let's take a closer look.
Step 1: Clean
I started off by cleaning the trailer with Marine 31 Port to Starboard All Purpose Cleaner and a Mothers Fender Well Brush. In my review of detailing the wheels and tires on Max's boat trailer (Boat Trailer Detailing w/Marine 31 Waxes, Cleaners & Polishes) I raved about how well Marine 31 Port to Starboard All Purpose Cleaner works on virtually any surface. It performed exceptionally well with the Mothers Fender Well Brush, one of my favorite detailing tools.
Step 2: Prep
A high-speed rotary polisher and a wool pad is the quickest way of restoring the shine and luster to metal surfaces. Combine the direct-drive power of a high-speed rotary polisher with the fast cutting action of a wool pad and you'll remove oxidation and staining in no time.
Following the theme of "work smart and not hard," I equipped my Flex PE14-2-150 - the smoothest running rotary polisher money can buy - with a 6.5 inch BLACKFIRE Level 1 Pre-polishing Wool Pad. This combination, when paired with Marine 31 Finish Cut Metal Restoring Polish, made quick and easy work of removing the oxidation from the stainless steel fenders.
Whenever you're starting out with a brand-new wool pad, you first want to use a wool pad spur on it. This removes any loose fibers from a new pad or any contaminants that the pad could have possibly picked up. A wool pad spur from Lake Country will quickly become one of your most valued detailing tools when working with wool pads.
Step 3: Polish
After cleaning my pad I started polishing. Marine 31 Finish Cut Metal Restoring Polish cuts exceptionally well for the mirror-finish it creates. Its thick formula is eco-friendly and its smell won't offend you.
Note that I had a Rotary Backing Plate Extension equipped on my FLEX PE14-2-150. This made it easier to see the working area as the body of the tool is placed farther away from the backing plate/pad.
My backing plate of choice was a Flex-Foam HD Rotary Backing Plate. This backing plate features a flexible construction which makes it easy to transition from flat to contoured surfaces, like the rolled edge on the diamond plate fender.
Step 4: Protect
After polishing the diamond plate fenders to a mirror finish I applied a coat of Marine 31 Gel Coat Carnauba Wax + Sealant.
Marine 31 Gel Coat Carnauba Wax + Sealant is designed to provide the utmost in surface protection for gel coat – standard and painted. Real carnauba wax fortified with advanced crystalline polymers locks out UV rays and prevents salt from degrading the underlying finish. Exceptionally easy to apply and remove, Marine 31 Gel Coat Carnauba Wax + Sealant creates a mirror-like finish that lasts.
Marine 31 Gel Coat Carnauba Wax + Sealant makes for an exceptional metal sealant as well, making it the obvious choice for protecting the wheels and diamond plate fenders.
I applied it by hand using a Gold Wax Finger Pocket. These are great because they're super soft and they keep your fingers protected from any sharp edges.
After letting Marine 31 Gel Coat Carnauba Wax + Sealant dry to a haze, I buffed it off using a All Purpose & Wheel Detailing Towel.
Step 5: Put on your sunglasses!
In no time at all Marine 31 Finish Cut Metal Restoring Polish paired with the lean, mean, FLEX PE14 restored the shine and luster to the diamond plate fenders.
With the right metal polish and tool for the job, polishing your diamond plate, aluminum or chrome surfaces doesn't have to be such a laborious task.
Marine 31 - Waxes, Cleaners & Polishes
