Wors
- Jun 15, 2012
- 783
Two older sets headlights ready to be tested against the DP AIO Headlight Restoring Polish. After great results last week on the Subaru I lined up a CRV and another Subaru.
First, the Subaru headlights and LC Cyan Low Profile HT foam.
Products used:
Setup for PC, pad, and DP polish.
Before - Front Left
After - Front Left
Before - Front Right taped off
50/50 - Front Right
After - Front Right
Next, the CRV lights with a LC thin foamed wool pad.
Products used:
Before - Front Left
After - Front Left
After - Front Right
Whatever pad is used be sure to clean the pad after each section. The wool pad and foam pads load up quickly. The wool pad does cut faster than the foam pad but both worked extremely well.
Both sets of headlights were a huge improvement. The CRV headlights did have some deeper scratches that would have required sanding to remove. A quick tape and polish provided very good results.
Both customers were extremely happy with the results.
Products used:
• Porter Cable 7424XP
• LC-43-073DA Dual Action 3 Inch Flexible Backing Plate
• DP AIO Headlight Restoring Polish
• 3" X 7/8" Cyan Low Profile HT foam
• CarPro Eraser
• Optimum Opti-Lens Permanent Headlight Coating
• CarPro Eraser
Before - Front Left
After - Front Left
50/50 - Front Right
After - Front Right
Products used:
• LC 3 1/4 Inch Thin Foamed Wool Pads
• CarPro Eraser
• CarPro Eraser
Before - Front Left
After - Front Left
After - Front Right
