Angus
- Jun 14, 2012
- 1,583
For this review, I’m going to share my experience using 303’s brand new Rubber Seal Protectant on my 1998 Honda Civic.
From PBMG’s copy for 303 Rubber Seal Protectant:
Directions:
1.Shake well before use. - Check & ready for use:
2.Apply 303® Rubber Seal Protectant evenly onto a dry, clean surface using attached foam applicator. - Check. *Application Tip* There’s a valve hidden underneath the applicator sponge that needs to depress in order to break the factory seal and thus allowing product to flow freely.
Door seal:
50/50 on rear side window seal:
Trunk seal:
Sunroof seal:
Protects rubber seals against drying and cracking
303 Rubber Seal Protectant conditions rubber seals on doors, windows, hoods and trunks to help prevent long-term drying and cracking. If you have an older vehicle with discolored door seals, 303 Rubber Seal Protectant will rejuvenate the color while restoring elasticity. 303 Rubber Seal Protectant is 100% water-based, and the shoe-polish style applicator makes application quick and easy.
The rubber seals on my Honda are original and showing their age. Up until now I’ve been using 1Z’s Gummi Pflege to maintain them however it’s been quite a while so now is the perfect time to test 303’s above claims. 303 Rubber Seal Protectant conditions rubber seals on doors, windows, hoods and trunks to help prevent long-term drying and cracking. If you have an older vehicle with discolored door seals, 303 Rubber Seal Protectant will rejuvenate the color while restoring elasticity. 303 Rubber Seal Protectant is 100% water-based, and the shoe-polish style applicator makes application quick and easy.
Directions:
Door seal:
Trunk seal:
Sunroof seal:
