The Guz
- Jun 17, 2013
- 8,773
- 46
I picked this up as part of my purchase at the local 3D store. Decided to put it to use and to distract me a little after getting home yesterday seeing the results of my dad's Camaro stripped. It's like losing a family member. As well as my grandfather who is having some health issues.
Product link:
3D Liquid Leather
Product Description:
3D Liquid Leather combines everything you love about leather cleaner and conditioners, without some of the most common annoyances. Designed to perfectly clean embedded dirt and grime while finishing with a smooth layer of protection, 3D Liquid Leather does not leave behind a greasy, streaky mess. Enhanced with Mink Oil, 3D Liquid Leather cleans and protects not only your leather wrapped seats and buttons, but will treat vinyl and plastic surfaces the same way! Think of 3D Liquid Leather as an all-in-one interior cleaner & protectant!
Leather is a soft and very supple surface that requires constant care and maintenance to keep it looking new. Even repeatedly getting in and out of the car is enough to cause leather to fade, discolor, and dry out. Over time those repeated assaults leave your leather looking worn and faded, even if it’s only been a few years. Luckily, there have been leather products introduced to the market that can prevent this from happening in the first place.
3D Liquid Leather is one of those life (or leather) saving products. Formulated with Mink Oil for extra softness, 3D Liquid Leather leaves your surface clean and conditioned in just one step! Add to that convenience the non-greasy formula, and 3D Liquid Leather is a match made in heaven.
After all of your leather surfaces have been cleaned and conditioned, you are free to use 3D Liquid Leather on all other interior surfaces! Plastic dashboard pieces, vinyl door panels, and even plastic trim. Keep your total interior area clean and protected from UV rays, everyday movement, and the unexpected elements with 3D Liquid Leather.
Product video courtesy of 3D:
Front of the bottle
Directions on the rear of the bottle
It's a bit hard to tell with the lighting but the product is a white gel like consistency. Similar to Meguiar's D181 Leather Cleaner and Conditioner and HD Protect.
I used a microfiber applicator to test out the cleaning ability of the product.
50/50 on the lower part of my chair. This is right after application.
I applied it to the remaining section. I came back with a microfiber and lightly buffed it. It gave a matte like appearance.
There was some dirt removed from the chair. It was not a whole lot as I hardly sit in the chair.
Initial thoughts:
I am going to give my initial thoughts until I actually use it on the interior of a car. I can't put my finger on it when it comes to the scent. It's almost like a leather type scent. It is very similar to HD Protect. It did go on very easily and a little product went a long way. Especially once the pad has been primed with product. It appears to be doing some cleaning action. For those of us that regularly maintain our interiors, this would be more than enough for an AIO. It is non-greasy. It did not leave a sticky feeling. The shine can be controlled.
So far this looks to be like a good product.
It says it can be used on all interior surfaces, so I am looking to use it like that.
For $8, it's worth giving it a shot.
Product link:
3D Liquid Leather
Front of the bottle
Initial thoughts:
