Review: Black Fire Bug Blocker on my Ford truck
luckydawg
Active member
Recently Mike Phillips wrote a review for a new product to protect your car from damage caused by bug splatter. The product also makes removing dead bugs faster and easier as they wash off when you wash the product.
Below are some pictures showing the application of BF Bug Blocker, then after my last trip, washing it off and finally showing my Ford Truck back to it's clean self again.
The product is a thick gel and applies best with an applicator pad or brush.
Here I'm applying to the plastic round the headlights....
Here I'm brushing on the Bug Blocker into the crevices between the body panel and headlight. If bugs get into tight spaces and dry they can be almost impossible things to remove.
A brush comes in REALLY HANDY for grill areas like this and I'm just dabbing it in kind of thick...
Can't really see it but I've applied the Bug Blocker all over the A-pillar as a lot of bugs impact this area...
You can see the brush marks in this picture but after a few minutes, this product flows out to a uniform layer and can actually be very hard to see.
Here she is, at this point I've applied the BLACKFIRE Bug Blocker to the entire front of the truck. Any surface that a bug would impact onto has been coated. But as you can see, the product flows and gels together to create a uniform layer that become invisible to the naked eye.
Here's after my trip from Crystal River, Florida to Pawley's Island, South Carolina, about 475 miles one way. This is after driving there and back, so a trip of about 950 miles. When I parked the truck for the night , I had no idea that I parked it by a sprinkler, when I came out the next morning and saw that a lot of the bugs were gone, and figured out a sprinkler had hit the front end and washed a lot of them off-- I knew right then that this stuff was good.
So by this time I am home from my trip and ready to wash the truck and as you can see there are lots of bug bodies all over the front of the truck and these have been on for 5 days now.
Here's my wash bucket with car wash and BLACKFIRE Foam Booster and a microfiber towel.
This is my old bug sponge, normally I would need this to scrub the bug carcasses of my truck and as you can see, I've used this bug sponge a LOT! But with the BLACKFIRE Bug Blocker it simply wasn't needed.
There's no scrubbing needed, all I'm doing is using the soapy water and the microfiber towel to gently agitate the surface and everything peeled right off.
Here's the results... completely clean without zero bug splatter left behind.
The Bug Blocker worked GREAT!
The problem is, the bugs are still here and now they're attracted to my clean shiny truck! :dunno:
So in summary I will say that I do like the product, its easy to use and apply and does make a very big difference when removing the bugs - considerably less effort.
If I had a vehicle that constantly accumulated bugs I would use this pretty regular. Since that's not the case for me, I will use it on all 3 of my vehicles during May & September and when I go on any extended road trips (3 hours or more one way).
For me, when this bottle runs out, I will be buying another one- that should tell you what I think of it.
Thanks again to Mike Phillips for letting me test it out!!!
:xyxthumbs:
Awesome that it actually did work! And a great review of it.
Did you see any signs of the lovebugs did any etching?
How is it with the radiators after a season of these lovebugs? It's a hard to reach place and even if the plastic trim has been better to cover direct hits on them. I useally see a big build up of bugs on some vehical modells. And on older vehicals the radiators can be very brittle when you hose them down even. Is it something that you useally pay more attention on getting them cleaned?
Thanks for shareing your experience with us!
/ Tony
It looks like the product is blue. I’m only familiar with Pro Bug Guard which is clear and does the same thing. I wonder why Blackfire chose to color it
Wow. Awesome review. I’m wondering if this stuff can be put in a hvlp gun with a bigger nozzle. That would make application a breeze.
/ Tony
The etching only comes when the splattered love bugs are left on the painted surfaces for an extended period of time-- how long that is-- I am unsure. I do know that after a few months for sure that there will be etching. I never worry about etching anymore cause after getting "burned" by that one time, I ALWAYS wash them off no later than a few days-- I have learned my lesson with these.
As far as the radiator is concerned- all you can do there is just spray your straight stream from the hose thru the grill and hope for the best to get out as many as you can. BUT NEVER pressure wash the radiator- you wont like the results.
Sometimes when it comes to the radiator, I had to blast it with just garden hose pressure and pick out whatever bugs were left behind with tweezers. Tedious job.
Now that's a great idea but I'm not sure it will work due to how thick and gel-like the product is. It's pretty thick.
Another option might be the Optimum Spray Gun?
Optimum Spray Gun
Or just wipe it and brush it on like shown. Sometimes simple is easy and simple is best.
Great review!! I don't deal with bugs like that. Not anywhere near close to that. But if I do another road trip, like back in July, then I'll pick this up prior to the trip. :)
Awesome review, now we need to develop bug repellent to go along with this! :laughing:
PS love Pawley's Island, we go every summer and love to hit the Hammock Shops!
Went went Litchfield by the sea resort for a convention- ----amazing beach
:bump:
Just to note - right now there is a 50% off sale for this product. It's exactly what I say it is. So this is the time to buy it to test it out or if you've already trusted me and purchased it and found it to be what I say it is then this is the time to stock up.
PBMG brands 50% off sale
The sale is good for 24 hours and at the time I'm posting this, 11:00pm on Thursday, March 26, 2020 you have 13 more hours to get in while the getting is good.
